Disk imaging-Cheap peace of mind for me. *LINK*
Curt Harms
>I've used a shareware product (yes I paid for it)called Image for Linux. I'm not a Linux guru and you don't have to be. Once I paid for it I was emailed a link, order # and key. I downloaded an image from the publisher's web site and burned a CD from it. The CD is bootable. You just insert the newly created CD and reboot. If the BIOS is set to boot from the CD if found (most are it seems), it'll boot without any imput.
Select the partition you want to back up, tell it whether to back up the entire partition or changes, insert a recordable CD or DVD and press "go". The reason I went with the Linux version is that Windows is not operating at all so there are no file changes during the backup process. The advantage (or disadvantage) is that EVERYTHING in the partition is backed up. Why disadvantage? If you have any malware on your HD it will be backed up too. I make an image when I first buy or build a machine so I can restore any hard drive to that exact configuration and put it away. I make another image after I install the programs I use. That's the one to use for restoring if the reason for restoring isn't a malware problem.
The image disks are self booting so you don't need to use the image program to restore the disks. This also works well for installing new hard drives in existing machines. The same program is available for DOS & Windows but it seems reasonable to my non-techie brain to not have active the thing you're trying to back up. You can download a trial version which I believe will create an image but that image won't be self booting, you'll need the paid version in order to do a restore. The trial will give an idea how it works. There are other options available-Acronis True Image is one-but I have experience with those.
Image for Linux
