REAL MILK PAINT
OT-CO Detectors
OT-CO Detectors
OT-CO Detectors
Sawman
>I need to finally install one! So I see that my choice is 120v hard wire with battery back-up or a battery only.
Suggestions?
Re: OT-CO Detectors
Re: OT-CO Detectors
Howard Norman
>I have been using a First Alert model for some time now. It is 120 plug-in AC with a 9v battery backup. Have been satisfied.
Re: OT-CO Detectors
Re: OT-CO Detectors
Rob Hix - King George, VA
>I had rather have the 120V with battery backup. Just remember, do not get one of these things and mount it on the ceiling. CO is heavier than air, and the entire room will have to fill up before the thing will go off. At that point, the alarm will probably do no good. Mount it as close to the floor as you can. The closer you mount it, the more timely the warning.
Rob Hix
Re: OT-CO Detectors
Nighthawk; reads more than CO levels
Joe Pack
>One recommended by our local fire department is the Nighthawk 120v. w/battery backup, which is what I installed about 8 years ago. At least a couple of years ago, they said too many CO detectors had problems with false readings causing them to go out on too many unnecessary runs. I remember having read something about that, too.
One thing that did surprise our local fire dept. was that my Nighthawk also was sensitive to gases put out by an overcharging 12v. marine battery! I had a backup sump pump system powered by a 12v. automatic charger/battery system that did not kick off properly. The battery was being slowly "boiled" by the charger. My CO detector went off, so I called the fire department to check it out. They found no CO, not even at the furnace burner, but their meter showed some sort of reading that got stronger as they approached the sump area. Right at the battery the meter all but jumped off the scale. So, evidently my Nighthawk reads sulfuric acid levels too! The fire chief checked with other sources and found that, yes, this is not an unknown thing.
Re: OT-CO Detectors
Re: OT-CO Detectors
Alexander Grigoriev
>CO molar mass is 28, while the air mean molar mass is amout 29. This, CO is lighter than air.
