Have a question? Ask Woody!
How to route an irregular circular groove
Dan Mitchell
>My wife is a potter, and she recently made a base for a round table lamp, approximately 9" in diameter. The image below is of the inverted base, looking into the interior from the bottom. I would like to make a wooden disk for the lamp to sit on & fit into, basically by routing a groove in a disk. The problem is the bottom of the lamp is irregular, so while I have a circle jig for my router, a perfect circle would not fit. How can I make a pattern for my router to follow to route a groove which would be an image of the bottom edge of this lamp, or how could I use the lamp itself for this in some way?
TIA
Dan
Re: How to route an irregular circular groove
Re: How to route an irregular circular groove *LINK*
Dan Donaldson
>Is the wooden base larger than the round part? I mean, you want to cut a groove in a piece of wood for the base to fit into? If that is the case, I would put the base on the wood and trace around it. If it doesn't have to be too deep, then I would put a small (1/4 or 3/8, maybe even a 1/8 if there is a lot of small detail in the outline) spiral bit and follow around the profile freehand, then put in a larger bit and clear out the rest. The interior would not have to fit, just clear the edge. It is not too hard to freehand with a router, you just have to be careful. I roughed in all of the carving on the attached link freehand with a PC690 router.
Carving roughout.
Kneale Brownson dreaming of snow in N. MI
>I take it you want a hollow base the ceramics will sit into. For that, I think I'd trace it, establish and cut out the outside perimeter you want for the base, use an edge guide to establish the hollowing perimeter and then freehand the rest of the hollowing.
>You could use the pottery as a pattern. Bolt a piece of wood to it or use double stick tape and then route around it using a bit with a bottom bearing. That would give you a piece that matches the shape of the outside. Then use a rabbeting bit to cut a should on it the same thickness as the rim of the base. At that point you could use a bit with a top bearing to trim away the original edge and you would have a piece that would fit entirely inside the base. Then glue it to whatever you want the lamp to sit on.
Or, you could make a base you like that is flat on top and just glue four or five blocks on it to keep the base in position.
Use the threaded "Pipe" up through the lamp to hold it all together.
Or, if you have a Dremel or Rotozip you could use a Rotozip bit to cut out a base. Just double stick tape the base to the piece of wood and "lean" bit outward as you go around and it should fit fairly well.
PS, You can never have too many router bits.
Fred Davis
>Barry's first paragraph covered it all
FredD
GalenV
>I take it the pottery has been fired so now too hard to sand the bottom flat so it can set on a flat disc and then you would not have to worry about the perfect groove?
Not sure what the outer surface of the lamp looks like but if irregular then set it on a natural slice of a log with the bark still on and slightly irregular. Maybe too "rustic" for what you are doing.
Dale Lenz
Dale Lenz
>I'd do what Barry suggested except a few things.
Trace around the pottery with a medium point sharpie, put masking tape on pottery if you think you might get ink on the pottery. Cut to the outside of the sharpie line. Then attach about 3/32" of washer thickness to the inside of the pottery lip in 4 places: 0, 90, 180, & 270 degrees. The washers give you a slight safety margin of not cutting into the pottery with a flush-bottom bearing pilot router bit. Then do the rabbet bit as Barry suggest.
Steven Antonucci
What I would do.
steve antonucci
>I would make the base with my circle jig with a step in it. Make the step just a bit too large to fit into the recess. If your wife doesn't mind, since it's the underside of the lamp, just mark the underside with some old lipstick. I
f you try to fit the step into the recess, the lipstick will highlight all of the pieces that need to be cut away. Use a chisel or a router or whatever you are comfortable with until it fits the way that you want.
Steve
Would this non-router method work?
North of the Border
>If the objective is simply to hold the pottery down on the table / desk, this may work:
1) Lay the pottery on the table, and trace the exterior outline on the tbale
2) Draw out the interior line (x inch from the exterior outline where x = the thickness of the pottery)
3) Install / screw several small wooden blocks along the interior line for a tight fit (edges of blocks may be roughly sanded or rounded to fit the internal profile of the pottery)
4) After test fitting, glue the blocks.
Dan, That Was Inspirjng
That one sounds like a winner to me...
John E in SC
>As a variation on that, you could route or drill a slot underneath for a screw going up into each block, then when you put the lamp on the base, you could slide the block over till it's tight into the pot (might even put a dab of silicone or something on the block if you want to glue it to the pot), then tighten the screws, and you're all done.
Let us know what you end up doing, and I'd love to see a pic.
John
>That's almost exactly what I do when I route raised letters into my mirrors. I route away most of the waste with a 1/4" and 3/8" bit so there is just a little to remove near the letter. Then I put a 1/8" bit in and route as close to the letter as I dare. The 1/8" bit is very controllable so you can get very close. The Edge of the letters show so I leave the pencil mark and then carve this away with hand carving tools. That gets rid of any burn marks. Your lamp base would be pretty easy this way.
Dan Mitchell
>Thanks for all the helpful replies. One main motivation in this is my wife wasn't thrilled with how the very bottom ~1/2" of the glaze came out, and she wanted to cover it up (it looks fine to me ;-) So what I was thinking was a groove which the base would sit in, with a lip that would come up on the outside to cover that bottom 1/2" on the outside.
Now she's leaning toward asking her pottery teacher if there's any type of covering (paint, etc) to blend this bottom area with the portion above it.
If we do go with the grooved base, I think I'll try the freehand with a spiral bit approach 1st. I do have a fair number of router bits, and even 2 routers at this point, but I've been looking for an excuse to buy/try some of those solid-carbide spiral bits!
Thanks all again for the suggestions!
Dan
