Adhesive Question...
Rob Hix - King George, VA
>Hey all,
I am in the middle of putting together some Christmas presents which require me to glue some cork to some plywood. I thought I would be industrious and buy roll cork and use contact cement to glue it to the board. This has turned out to be a total disaster. I had to get water based contact cement because I needed to work inside (temperatures). Needless to say the stuff I bought at Lowe's did not work. Not one bit of adhesion not matter what I do.
I would still like to use the cork, but I cannot use the solvent-based contact cement in the house (unless I want a divorce). I was thinking 3M Super77 adhesive might work also. Anybody here with an opinion on this, or preferably, with experience with this. Will the Super77 work or do I just need to forget the cork?
Thanks in advance,
Rob Hix
Re: Adhesive Question...
Ken Oakley-Sunny St. Cloud, Fla
>My experience with the 3M 77 has been very good. Spray both surfaces, allow to dry to the touch and press surfaces together. I still prefer the solvent based contact because I get a high as a bonus. At my age I take highs anyway I can get them.
Bill Tindall, E.TN
>I would use the 3M High Strength 90. Coat both surfaces. I use this stuff for gluing heavy abrasives onto shaped forms for sanding profiles.
Of course this product is solvent based, which you said you would not use. It would seem that any material could be applied out doors and left there to flash off the bulk of the solvent.
I would add that all the water based materials have a substantial amount of solvent to coalesce the adhesive particles.
>Bill,
Outside is ok for something like 77 or 90. It looks like both of these products require like 30 seconds to 1 minute before sticking together, and it looks like they are favorable too my temperature right now.
Thanks for the info. Do you know if places like the borgs usually carry that stuff?
Thanks again,
Rob Hix
answers
Bill Tindall, E.TN
>It looks like both of these products require like 30 seconds to 1 minute before sticking together,............it can be longer and the temperature is not important. The solvents are very low boiling and you can bring it inside to finish evaporation.
. Do you know if places like the borgs usually carry that stuff?........yes You will find the 90 right next to the others.
Fred Davis
>Rob ,
save yourself some money , get a caulking tube of "Clear PolySeamSeal adhesive caulk" works every time , but one caution, it is a permenent bond.
FredD
Re: Adhesive Question - Update
>Hey all,
I think someone mentioned giving it more dry time than is on the can. Well, originally I tried it again after an hour, and still no luck. Well, last night I tried it one more time while trying to decide what to do with the ruined pieces. It worked like a charm. Here's the kicker. I waited 12 hours between coating and sticking. I then tried some more before I went to bed last night. Six or seven hours later (this morning) they stuck better than the ones last night.
Now, I went yesterday and got some Super90 and plan on using it this afternoon to knock out the rest of these things, but I wanted everyone to know that the contact cement did eventually work.
Thanks for the advice,
Rob Hix
Re: Does wood glue not stick to cork?
pecker
>Seems like it should, but I've never tried.
