Grinder decision
Grinder decision
Grinder decision
Allan D
>Okay, I have my arkansas stone flat now. What to do about a grinder? And stay around $100.
I have an old but servicable 8" 3/4hp 5/8" shaft 3600 rpm grinder. The wheels are shot. I could buy one of Joel's Norton 3x SG wheels and a diamond dresser.
Or I could buy a new 8" 1750 rpm grinder with two aluminum oxide wheels from Woodcraft.
I'd like to be able to form a primary bevel quickly without burning the edge.
Any opinions?
Re: Grinder decision
I got one of the slow speed ones at Woodcraft *LINK*
Dan Mitchell
>Had to return it because the fine stone was so out of true, it actually rubbed on the housing. We opened 2 others at the store, same problem, so I just got my $$$ back.
Ended up getting one of these HF wet sharpeners, on sale & w/a coupon for about $69. Works great.
Dan
http://www.harborfreight.com/cpi/ctaf/displayitem.
considerations
Bill Tindall, E.TN
>1. the grinder you have is just fine but it will take some practice to use it.
2. To grind tools you need a good tool rest- large, flat and close to the wheel. Either make one or buy the One Way Wolverine. I'll try to remember to post a PIC of a simple home made rest tomorrow. Fastening a large plate to the typical grinder tool rest is another alternative.
3. There is much misunderstanding about the 3X wheels. Read my article on wheels in the Articles section. The white wheel from Lee Valley is a good tool grinding wheel as are others. The 3X wheel runs no cooler than a lot of other wheels. It will run cooler in a harder bond than wheels without the special particles that comprise 30% of this wheel. This attribute will enable the wheel to hold its shape better. This feature is important for turners grinding rounded tools which can groove a soft bond wheel. It is less important for flat tools. In my opinion if one needs the attributes of the consumer 3X wheel, it makes sense to buy the commercial version (called SG or ceramic wheels) that have more of the special particles.
4. An ARK stone is a slow way to grind hard tool steel. I suggest you investigate other abrasives for refining the hollow grind left by the wheel. I prefer a fixed diamond stone in a fine grade followed by further refinement with some fine abrasive. An ARK stone could be ok here but a water stone would be faster.
Get the new wheelss and a diamond dresser
Forrest Addy
>Get the new wheelss and a diamond dresser. About 90% of grinding problems derive from failure to dress the wheels properly. Grinding wheels are cotting tools and have to be "sharpened" periodicaly. Since the cutting edges are the abrasive grains you shapen the sheel by removing the top layer of dull grains to expose fresh sharp ones.
In a perfect world the wheel id make to break down in use so the dull grains are ecjected but practically speaking this process has to be helped by physically dressing the wheel to round it up, shape the face and the actual dressing.
The simplest tool for this operation is a hand shank and a diamond cluster dresser. These are available from MSC and other industrial supply houses. The low cost diamond plated arrangement work well but not for long. The diamonds are very hard but even these are slowly consumed in the dressing operation.
The low speed grinders do work when the wheels are new. Sad to say even low speed grinding wheels get dull and you have to dress them and you're back where you started.
Get the diamond and the hand shank. Best $75 you ever spent. I'd post links to the choices I would reccommend but the MSC website is partly down for maintenence at time of posting.
MSC wheel recommendations
Bill Tindall, E.TN
>For the hard steel used in our tools I like (and manufacturers recommend) the wheels described as "pink", though white is ok. You may have to buy a bushing to adapt the wheel to your shaft. They are cheap. For plane irons and chisels get a "H" bond as it will stay sharp longer between dressing. For these applications a 1/2" 60 or 80 grit wheel is ideal as you will crown it and only be using 3/8" or so of the wheel to grind.
For production grinding, or for the turners who seem to grind constantly, consider a "SG" or "ceramic" wheel for longer wheel life (they are often blue in color). These wheels contain 50% or more of the special particles where as the 3X consumer grade of wheels have 30%.
Bought that same grinder recently...
John E in SC
>Mine had the same problem, but since I had mail-ordered it (free shipping), I decided to make it work. I spent an hour or so working with it. The metal covering over the wheels was bent, and the wheel just wasn't seated properly. I also spent some time sanding and filing the tool rests, which were very rough, and at this point, I'm pretty pleased with it. It wasn't usable out of the box, but with a little "tuning", I think it's a pretty usable slow-speed grinder at a nice price.
John
Re: Grinder decision *LINK*
>Allan,
I must have some disease since I have 6 stationary grinders. I use a slow-speed grinder and a Tormek for lathe tools.
I bought the slow speed grinder from Woodcraft about 6 years ago and it is great, especially since I added the Wolverine jigs. The wheels that came with it were always a bit out of balance which caused some vibration on the table but not too much to use effectively.
I recently replaced the wheels with Norton 3X wheels riding on the Oneway static balancing system. The result is silky smooth so the problem was in the cheap wheels, not with the grinder itself which appears to be well made.
I on advice from Doug Thompson, I also acquired one of the single-point diamond dressers that Bill Grumbine offers. This thing is well engineered and I consider it well worth the cost - far better than any other wheel dresser I've used.
http://www.hartvilletool.com/product/10846
