Re: OT Anyone ever use GeeK Squad or....
Curly Smith
>You've got a registry problem or some bad dll's.
First, go to Add/Remove Programs in Control Panel, click the "Show Updates" box at the top, scroll to the bottom and look for "Windows XP Service Pack 3". Click on it if you find it, then click "Remove" and reboot your system.
Then, download and run CCleaner Slim (No Toolbar) 2.12.660 . The program has an "undo" feature but it's best to set a system restore point before changing your registry. Start the program, click on "Registry" and then "Scan for Issues". Delete all the problems that it finds and restart your PC.
If that doesn't fix your problem, try running System File Checker (SFC) by entering "sfc /scannow" in the Run Box. You may need your System Disk. Errors located will be reported in "Event Viewer" (access via "Control Panel" | "Administrative Tools") but any errors found will automatically be fixed by copying the needed files from either your System Disk or the Dllcache directory on your PC. You might check "Event Viewer" first to see if any errors are currently being reported and to make sure that your log file isn't full (if all you see is old entries then clear the file).
