ADVERTISE HERE - FREE TRIAL
Question on spraying finish...
Rob Hix - King George, VA
>Hey all,
We recently had a Harbor Freight open up in town. I stopped by one night and walked out with one of their 20oz gravity feed spray guns for $15.00. So far I have sprayed nothing but mineral spirits and water out of the thing, but I have been quite impressed it does a decent looking job. The only problem I have is that it did not come with a viscosity cup, so I am not sure how to mix up my finishes.
I am starting to work on my Christmas projects for this year, and I would love to use this gun to spray some lacquer on the projects. My question is, will this gun, with a 1.4mm tip, spray lacquer directly out of the can? If not, where can I get a viscosity cup and what is the proper viscosity of the lacquer for the spray gun.
Any help you could give me would be greatly appreciated,
Rob Hix
Re: Question on spraying finish...
>How well your 1.4 tip will handle lacquer depends entirely on the viscosity of your finish. You'll need to find out what your finish manufacturer recommends. For that you'll have some internet digging to do or asking your supplier (or both). It/they will give the specs (like "70 sec. for a No. 2 cup" etc.). You can get a viscosity cup in various sizes at most any descent paint store.
Then too you must pay attention to the pressure rec's for the gun type and tip size. I've sprayed NC lacquer with a 1.0 tip in an hvlp conversion gun running at 30 psi at the gun. I did, however, thin the mix a bit as I remember.
hope this helps
pecker
>It ain't that critical. Those guns will spray most anything thinner than wall paint. Try the lacquer straight on a sample board. Then thin it 5 or 10 percent and spray a little more, till you get the results you like.
The finer the mist you can produce, the smoother your final finish will be. You will need to tweak the fluid and pattern size controls. These all affect the atomization of the lacquer.
