>Pretty soon I will be installing some 24" square tiles in our bathroom. So I have been checking around and it appears that most tile saws are not able to do a 24" cut. I called the rental places in town and all have saws that cannot cut a tile that size.
So I wonder....how about dry cutting with a circular saw and a diamond blade?
>Tom, how about cutting the tile half way and turn it around and finish the cut?
I bought a cheap ($70) wet saw at Lowes. It is like a mini table saw with a rip fence. It would allow you to cut tile of any length. It actually worked fairly well for the money.
I have one of these type tile cutters and it does a very nice job on large and small tiles. I can also do large radius cuts with it. I also have a pro type wet saw, but this one has come in real handy when I don't want to go through all of the setup of the wet saw.
This is the brand I have and it has a replaceable ceramic cutting wheel. This is not the place I got it from, just a site that had a nice pictures of these type of cutters.
>I use a Jepson hand-held wet saw (see link). It looks like a trim-saw, but has a diamond blade & water jet. It's not hard to put together a jig for tiles of any size.
You can run it dry, but wet cutting gives a much cleaner cut.
>I was hesitant to buy the cheap Lowe's saw, but did after the clerk pointed out that I had a 30 day no hassle return period if it didn't work. He said the only returns he was aware of were from people who bought it, used it to complete a small job, then returned the saw saying they didn't like it.
I used it to trim natural stone for an entry way. It worked perfectly fine, particularly for cuts where I needed to trim just 1/8" or so where other cutters would have had trouble. Imagine trimming with a table saw versus trimming with a scratch cutter and snapping off. Just make sure you use it outside or in an area where dirty water isn't a problem since the water tends to fly a bit. I did NOT return it after finishing the job. It was worth every dime I paid for it. ($75-80 +/-)
>Third on the $75 wet saw. I did three bathrooms and a laundry room with it. For the money, it was an excellent investment.
The only problem I had, was sometimes at the end of a cut, a small chipout would happen on the corner of the tile. I learned to slow the feed rate way down, as I neared the end of the cut, and to make sure that I fed the tile as straight as possible through the saw.
Since it is SO messy, I set it up on saw horses, out on the lawn. Safety glasses are a must.
>Tom, like Ken, I bought the Lowes tile saw and did some very good cuts with it. Bought 25 boxes of 11.75" tile...14 tiles in a box, and started removing the vinyl tiles in the rooms, scrapped clean the concrete, then buttered up corners of each tile real good and laid them following the pattern in the tiles so they looked consistant.
When I had to make curved cuts around the tub I laid down some paper and drew a pencil to the tub curvature, then transferred that design to the tile. Cut off on wet tile saw very nicely. After letting tile setup for a day I mixed up the grout we had chosen and smeared it around into the joints. I used 1/8" spacers bought at Lowes too.
So, after laying 350 tiles I feel rather proud that I saved a great deal of money in doing the job myself.
When finished with sawing for the day be sure you cleanup the saw real good because the silt will harden and it a bear to take out from nitches.
>Like Mike said...it is sooooo messy. I cut a hole in some visqueen for my head and made an apron so I wouldn't get spattered with the water.
As the water in the saw depleted I had a bucket of extra water handy and added a cup every so often while cutting tiles. Measured about 50 tiles for borders and cut them all at once....came out real nice.
For the money, I would recommend the $70-85 dollar saws at HD and Lowes.
>I bought one for tiling above the shower enclosure. Worked like a champ. Since then I've used it to cut tiles for a table project and to cut some thick (1/4") glass for another project. It has worked reasonably well with both.
Of course most of the time it sits in one of the cabinets.
>I hate to be different abt the box stores tile saws. My one time experience was different from what others have said. I was tiling my back porch with porcelain tile and borrored my SILs HD wet saw. I made about 2 cuts with it and no matter what I did it wouldnt cut any more. I took the blade back to HD and tole the gentleman my problem. He gave me a branmd new blade, took it home and the same thing happened. It just wouldnt cut that porceline tile. Went down to rent a real wet saw and didnt have any more problems. Dont know why, just did.
