What would you use to fill holes in Oak Flooring?
>I have posted several times about patching and sanding oak flooring in an old house I am working on for my cousin.
My original thought was to use some of the sawdust I have saved from the sanding and pack it into the nail holes and other defects and then soak it in thin CA glue and sand it off.
Now I realize there are hundreds of holes. Staples from pulling up carpet and pad. Holes where the tack strip was. And, for some reason someone nailed 4d finishing nails around the perimeter about four inches apart. And there are some dings and some cracks between boards.
So, something I could trowel in or put in with a putty knife would be good. Any suggestions? (Not sure if the floor witll be stained or left natural.)
Re: What would you use to fill holes in Oak Flooring?
>If the floor is gonna be sanded and refinished, I think it would be neat to emphasize the holes by filling them with a paste made of Durham's Rock Hard mixed with white glue instead of water and dyed with lamp black or iron oxide. It can be made up into a putty consistancy and schmeared in with a putty knife. It's a great filler.
Clint
Chuck in ND
>Barry, when I was refinishing hardwood floors quite a few years ago I was taught that gaps in boards you don't want to fill because wood floors move and eventually the filler will work it's way out, it's kind of a waste of time. For nail holes I think it depends on if your going to stain the floor or not would be a decideing factor on that you use. Personally for small holes I like water puty, Minwax makes a version of it also in different shades. Fill the holes before you put the last finish coat on. The nail holes you mention around the perimiter maybe from quarter round molding that was installed at one point in time, you may want to consider installing some if it would cover the nail holes.
John E in SC
>Check the Yellow pages and see if you can find a professional flooring supplier in your area - they sell putty made just for this, in various shades. It usually comes in gallon containers, and is fairly thin compared to typical woodworking putty. It's made to be troweled on over the whole floor then sanded off. Just a word of caution - I'm very glad I didn't spread the stuff over the whole floor when I put maple hardwood down in our bedroom - I did more of a spot fill, then realized that stuff was HARD when it dried. It took a good bit of sanding to level it off. But the color match is almost imperceptible.
Home Depot
Andy Halterman: 30s officially over
>Go to the orange borg and look for Park's floor putty. My local box has both red and white oak. I'd suggest using the white oak even for the red as most red oak fillers are way too pink.
If HD doesn't have Parks, both Woodwise and Timbermate (we use both) make good paste fillers that stain up very well. Just check for a local dealer.
HTH.
Andy Halterman
Eat, work, ride, sleep, repeat in Hendersonville, NC�
My X? :-)
Ralph Turney
Fred Davis
>What John said is true , the pros use a compound called Goop , have seen it used several times and they troweled it on , where you may want to be a little more neat then that.
They used a floor sander which you probably won't.
Local flooring suppliers that supply foola laying tools should have that or another under a different name.
FredD
Pat Riley
>Use a floor filler. Its pretty easy to find fillers for oak at the borg these days.
With the advent of central heat and air conditioning, wood floors don't move near as much as they used to, so fillers can work quite well.
The stuff does get quite hard. Last floor I did, I basically troweled it on with a 6" metal putty knife, let it sit for about 5-10 minutes, then scraped absolutely all the excess I could off with a large (8" wide) plastic scraper - you can usually find them with wallpaper supplies. That way there was not much left for the final sanding.
Timbermate Works Well
howard
Yeah, I clicked on this too...
Eddie Pacheco; San Jose, Ca.
>I thought, maybe, you might have some how-to instructions.
Re: Timbermate Works Well
Art Liebeskind
>NO, Timbermate is actually TERRIFIC and comes in about 10 colors....Water soluble, forever shelf life...no shrink etc.
www.timbermate.com
no connection etc. but I like it....It also can be thinned and used as a pore filler for furniture type finishes.
Re: Home Depot
Joseph Mulherin, Sr
>Barry, like Andy said, go to HD and purchase the white oak filler. Spread it around your nail holes and clean off with a rubber float like they use on ceramic tiles. Let dry for a day then use your ROS to do the sanding.
Re: Yeah, I clicked on this too...
Ralph Turney
>Sorry I wasted your time.
