Veritas - Innovation in Tools
Charlie's Grandmother Clock-Before Finish
>Good Afternoon Friends,
Previously I made a few postings which dealt with our grandmother clock, and a couple folks wanted to know more about the finishing schedule. The pix shows the clock just before Charlie and I disassembled it for transport back to his shop for final finishing. It is made entirely of cherry. Note Charlie is holding a can of the Black and Tan witches brew used to color the clock and to steady his hand.
George
Re: Charlie's Grandmother Clock-Before Finish
>Looking good Colonel. Now let's make sure that gravity doesn't take over this time! ;-)
Tom
Finishing Schedule of the Completed Clock
>This is the finished clock showing the waist door open. Charlie finished all exposed and non-exposed exterior facings including the back of the bonnet, bonnet top, waist, and base to the same schedule. First, he sanded the surfaces progressively thru 120, 220, and 340 grits, tacking after each grit thoroughly. Once he was satisfied, he applied black walnut flavored Watco oil by brush and let it stand no more than two minutes before thoroughly wiping it off. He worked individual clock sections, just a few square feet at a time to control penetration. He let the oiled clock sit overnight, and repeated the oil application as before, wiping it off almost immediately. After the second application, the clock "rested" for 72 hours.
Next, he applied two thin coats of Seal Coat dewaxed shellac. After the shellac was completely dry, he mixed BLO and naptha, 50/50 and applied that with 4/0 steel wool, rubbing it in. He removed all residual liquid with a soft cloth, taking care not to leave anything lodged in crevices or corners. The clock was again set aside to dry completely.
Another coat of Seal Coat was applied as before, followed by another application of BLO and Naptha, again rubbed out with 4/0 steel wool. He used wiping poly for six top coats, and the steel wooled BLO/naptha mix was applied after each of them, and after the final top coat.
All the repeated applications provided exceptional depth, smoothness, and mellow glow. The finish must be seen and felt in person to be fully appreciated. Charlie's technique isn't rushed, and requires more patience than I could give it, but his results speak for themselves.
I am developing a Shop Shot and narrative on this project, and should have it to David as soon as I can get the some of the pix down sized.
George
Re: Finishing Schedule of the Completed Clock
Finished Clock with Door Closed
The color shown in the pix is just above what the eye sees in Charlie's hallway. We paid special attention to grain selection, especially in the waist section and waist door. The pains taking finishing operation coaxed full emergence of all the grain's nuances.
For something I dumped and shattered on my shop floor, it doesn't look too bad. :<)
George
mdclor
>George,
That is beautiful! An heirloom for sure. I agree with you that I wouldn't have the patience for the finish process, but it looks great.
Merle
Question...
John E in SC
>What is the purpose of the BLO/Naptha mix, particularly between coats of poly? I wouldn't think it would be able to penetrate enough to do anything, and wouldn't really add to the final built-up finish either. Can't argue with the results as it looks great, but just wondering what the thought process was to justify all that extra work.
thanks,
John
Re: Question...
Howard Acheson
>Yes, that's my question too. To begin with, the Watco is an linseed oil and varnish mixture. When the varnish component dries, it effectively seals the surface and not further penetration of oil can occur. Applying the dewaxed shellac further seals the surface. Applying BLO at this point serves no purpose as it is being totally wiped off because it can not penetrate the film surface. Of course, applying a wiping varnish further seals the surface.
I would think the Watco followed by a couple of coats of a wiping varnish sanded with 320 paper between coats would have produced the same finish. But, it sure looks nice.
Re: Charlie's Clock-Absolutely Stunning !
Ray Carson - Lawrenceville, NJ
>I wish I could touch it. :-)
Ray
BILL White
>There's a hidden clue in this posting.
It took me a LONG time to catch on to the "waiting" time it takes between coatings during the finishing process. I was always in a hurry when it came to finishing. After all, it was the last component in completing the project.
Once I learned to slow down, finishing began to show good results.
Not like the beautiful clock project, but certainly better than I was able to achieve while in a hurry.
Bill
Re: Question...
Hello, John,
>The purpose for using BLO and naphtha in the clock finishing process is to create a lubricant to allow a super smooth finish. Each succesive coat of poly takes on a deeper look which uses light to the best advantage. Besides.it makes your fingers feel wonderfully icky!!!Thanks for your interest!!! Charlie @ THE COLONEL'S WORKSHOP
Claire Verna
>Hi Charlie,
Just wanted to thank you and George again for the beautiful job you did on the Grandmother clock. I think the Grandfather you built many years ago is a little jealous.
I also want everyone to know how proud I am of your many accomplishments including the many carved birds, hand-carved clocks, Santa's, Snowmen and Snowwoman, full-sized bust sculptures of Lincoln, Beethoven and good old Benjamin Franklin, and last, but not least, the absolutely beautiful 27 piece hand-carved Nativity Set with a very large stable with a real piece-by-piece shingled roof. I didn't mention everything, especially the gorgeous bowls you turned for our entire family, and my beautiful special jewelry box.
Thank you! Thank you! Thank you! Love, Claire
Lovely, George
>That is a real triumph. If you send me the larger image, I might be able to coax a little more detail for our starving eyes.
Nice work!
Re: Beautiful Colonel
Larry Clinton At Frankfort (Central)., Indiana
>I'm sure that will be a cherished heirloom for many generations. Hope you signed your name and date somewhere on the inside. In a hundred years or so someone will want to know the history.
