A55 Smoothing Plane
Sears table saw pully size
Wayne Carson
>FIL gave me a table saw need to know the pully size for arbor. It is a sears 113.298032.
Re: Sears table saw pully size
GalenV
>Since you have the Sears number have you tried to go on line to Sears parts and if your lucky they will have info. They have on my table saw and band saw both 35 and 25 years old. They had belt for my band saw and part list.
Dave Tenney
>If the motor RPM is 3450, both the motor and arbor pulley will be the same size...Example
If the motor RPM is 1750, then you want to end up with an arbor speed of around 3600 rpm, then look here:
http://www.csgnetwork.com/pulleybeltcalc.html
A 4" motor drive pulley and a 2" arbor pulley will get you 3500 RPM
Hope that helps,
Dave (Lurker)
Amplifying Dave's point
Rod Peterson -- Ormond Beach
>The overall answer to your original question isn't immediately apparent from Dave's comments (which are extremely useful, nonetheless). That answer is there isn't really a required pulley size for the saw. The two conditions that have to be met are motor pulley diameter-to-arbor pulley diameter ratio (which Dave addressed admirably), and physical clearance—that is, you don't want to select a pair of sizes that result in the belt rubbing on the table or sheet metal at either end of the blade height spectrum.
Rod
Sears saw sizes ?!?!?!?
>Ask Sally, she's down by the seashore selling sea shells ;)
Happy Woodworking!
