OT--Painting PT lumber
Henry Higginbotham
>I need to replace a window wall on the back of my house (five 4'x8' windows). I haven't really decided whether to use pressure-treated for the framing and trim, but assuming I do, what do I need to consider when painting it? And would Yellawood be better for painting than the green ACQ stuff? The Yellawood seems dryer if you can find it stored inside.
I go to a local paint store and the kid behind the counter appears to be about 12 (OK, I'm exaggerating, but not much), so I'm looking for the voice of experience.
Anyone?
Re: OT--Painting PT lumber
Gene Gauss
>I've successfully painted the older kind of green pressure treated wood using oil/alkyd based outside paint, after it was well dried. I don't know about the new stuff.
Glenn Madsen near San Francisco
>I've been doing this, as a hobby, for over 40 years. I've used PT for framing where it's needed, where water contact is reasonably or unreasonably expected, but no more than that. And I've never painted it. Framing is inside the walls, under the joists, somewhere pretty much hidden.
Trim today is frequently PVC or some man-made variant of that. It's consistent, reasonably priced, will last longer than we will, and works with the tools you already have. Go see the folks at the local pro lumber yard, and ask questions of them when they're not buried.
Fred Davis
>Henry ,
PT lumber is typically soaking we MC wise and a poor grade of wood , compared to #1 Doug fir, which used to be called "Standard and Better".
As you probably well know , wet , low grade lumber has inherently more problems then any #1 or #2 framing lumber picked for straight and dry.
Big box stores are poor place to buy lumber , go to a local lumber yard and tell what you want.
If your thinkling that PT will give you weather protection on your project, you rather should think good construction practices such using a paper flashing on the window rough opening and use a good grade of window , that is a market infested with junk.
FredD
Sorry, I didn't explain the problem very well
Henry Higginbotham
>I neglected to mention that the pair of 2x4s between the lights will be partially exposed (about a quarter inch reveal at the corners, beyond the stop and the trim), and so has to be painted.
Decent lumber CAN be had from a borg if you're willing to wait until they accidentally get some good pieces in stock, pick carefully, and rip 2x4s from 2x12s. Not perfect by any means, but plenty good enough.
So what I should have asked was how dry the PT lumber has to be before it's painted, and whether there's a problem with the chemicals leaching out later and causing problems.
Sorry for the confusion.
Re: Sorry, I didn't explain the problem very well
Curly Smith
>Generally speaking, you should wait 6 months to a year before painting PT wood. It obviously depends on how dry it was when installed and how much rain/snow/sleet it gets while it's drying. When you think it's dry enough you can sprinkle some water on it, if the water is absorbed then it's OK to paint. You can also buy kiln-dried PT wood that is ready to paint. Use an oil-based paint when it's ready.
There is no danger of chemicals leaching out of the wood unless you're constantly soaking and drying the wood.
I'm not clear what your planning on doing with the PT wood but if you use PT for framing then you shouldn't close the wall until the PT wood is dry. You really don't want that moisture trapped inside your wall. You should also be aware that it will try to warp as it dries which is likely a bad thing for a wall of windows.
If you're set on PT then go with the KD variety, otherwise buy some cedar or other weather resistant wood.
Fred Davis
>I read this recently ,
Time is worth more then Money
You can always get more Money
You can't get more time.
FredD
Drier pressure treated
Steve Schoene
>What you can't likely get from HD or others of the borg is pressure treated lumber that has been kiln dried AFTER treating (marked KDAT). Good lumber yards will be the only sources for this. I suspect that's what you want.
Thanks, guys
Henry Higginbotham
>I guess it would require a picture to explain the partial exposure of the structural 2x4s, but all the responses have been very helpful. I'll look into the local availability of KDAT lumber today.
