breadboard ends
Erick Singleman
>Okay, I put the last coat of finish on my dining table. After sanding and polishing, I will have approximately 4 coats of poly on the top and bottom.
Here's the question: My breadboard ends are flush to the table top meaning ther is no microbevel or other such rounding between them to act as a separator. That said, should I make a cut with and exacto knife or other blade to slice through the finish at this interface? As we all know the table will move due to moisture changes, and I am thinking that the finish that passes over this joint could get pulled and maybe fracture in an unfavorable way.
