Paging Jason Roehl - or any other paint dudes
Tim Greif - West of Chicago
>LOML is painting the basement walls - poured concrete foundation to be specific. She's putting on a single coat of Drylok to seal everything up. I suggested a second coat of inexpensive latex paint to finish it off. There is absolutely no moisture issue as I indicated in a thread a couple weeks back.
My question is this. Is there any reason to go with anything other than a flat latex? This is going to be white to just brighten things up. Is a flat contractor paint or even white ceiling paint recommended. Just looking for some guidance here.
Re: Paging Jason Roehl - or any other paint dudes
Jason Roehl in Lafayette, IN
>Mmmmm....yeeeesss?
If Drylok is going on first, you can do just about anything you want on top of it, within reason, of course. There's nothing wrong with leaving it or putting a flat interior latex on top of it. My only suggestion would be to consider an interior paint with a little sheen to it if the concrete has any amount of gravelly texture to it--it will be much easier to clean than flat paint. Satin or eggshell would help a lot in that regard. Texture plus flat paint tends to hold dust and dirt more than shinier paints.
Jason
Dale Lenz
Re: When I sold paint...
Dale Lenz
>was told one reason ceiling paint was so cheap in price: Did not have an additive for washing, ie the scubability of ceiling paint was not good. Based on what I think I know, would not think ceiling paint would be a good wall paint. Please correct me if I'm wrong.
May I add something as well?
Michael Dresdner
>First, ceiling paint is cheaper because it is made with a higher pigment to binder ratio. Pigment is cheaper than binder resin. More pigment means better hiding, so one coat will usually do a ceiling, but more resin means better scrub resistance and easier cleaning without white coming off when you scrub. Hence, wall paints have more resin, may require more coats to hide, and clean better.
Now, as to the basement, while wall paint will certainly do, because basements are often more damp, (and the damp may come from the floor as well as the sealed walls), I would choose a bathroom paint that is mildew proof. Yes, it is a bit more expensive, but unless the basement is always bone dry, you may be happy you did that.
