OT: Planting Acorns
OT: Planting Acorns
OT: Planting Acorns
Tom Rex in TX
>Anyone familiar with growing an oak tree from seed?
I've had good luck with maple but no success with oak.
I'd like to impress the grandkids.
Thanks for the help,
Tom Tex Rex
Re: OT: Planting Acorns
We have no problem
Lee Schierer - McKean, PA
>We have a red oak tree on the south side of the house and every spring we get a bunch of oak tree sprouts from the previous years acorns. I don't know if they have to be cold for a period of time to make them sprout.
Lee
Re: OT: Planting Acorns *LINK*
Bob Lemon Sacramento Ca.
>2,670,000 for starting acorns
starting acorns
I have a small fortune!
>I looked at the link and they want $3.00 for 10 red oak acorns. I could fill several bushel baskets with those from my tree. I wonder how many acorns are in a bushel.
Lee
Re: We have no problem
>>... don't know if they have to be cold for a
They will sprout right away if kept moist. I had 30 gallons sprout last week when a lid on the can kept the moisture in. I've also had big piles sprout and make a beautiful green carpet of little seedlings.
John McGaw
>If the acorns are fertile and are planted before they have time to degrade, it is hard for me to imagine that you could _stop_ them from sprouting. I've got several different sorts of oak trees in my yard and every spring I find nuts still sitting on the surface that have sprouted and sunk a tap root far enough into the ground that they are nearly impossible to pull out. Same thing happens with hickory nuts. And holly. And juniper (red cedar). And poplar. And ash. And beech. And don't even get me started on maple trees -- they come up so thickly that I am forced to mow them down or douse them with herbicide.
Any native tree in its own region should require almost no provocation to sprout successfully. I'd suggest that you simply follow along with how they've propagated themselves for millions of years.
Curtis Gray
>Pick them up when they are green and store in the refrigerator over the winter. This will prevent the worms which consume the interior of the acorn from doing so. At the first sight of springtime. Plant in a raised bed and keep moist until they sprout. Works on Live Oak for sure.
About 4650
Curly Smith
>Based on a random selection of acorns in my yard that measured approximately 1" in length and 0.6" maximum width.
The acorns are oblate spheroids and, based on the measurements, have a volume of 0.314159 cubic inches (or PI/10 cubic inches, interestingly enough). Formula for volume is 4/3*PI*a^2*b where a=0.5 (long radius) and b=0.3 (short radius).
If we divide the volume of a bushel, 2150 cubic inches, by the volume of an acorn we get 6845 acorns to the bushel. However, that over-estimates the number of acorns since it doesn't account for the void space. Perfect spheres will have a packing density of about 75%, meaning there's 25% void space. The most popular oblate spheroid, the M&M, has a maximum packing density of 68% so multiplying 6845*68% gives 4655 acorns.
Now you know how to "guess" the number of jelly beans in the jar...
Re: About 4650
>Note that unlike a quantity of spheres or M&Ms which are all the same size, the acorn mix may contain a number which are somewhat smaller so the total may be a bit higher. I think you ought to count them.
My neighbor has been picking up acorns for hours every day (nothing else to do!) and I am spreading them in my woods as wildlife food. I saved about 100 gallons in buckets and cans - I like to throw a scoop out in the dry lot and field to give the goats something interesting to hunt for - they love them! With the biggest acorn and hickory nut crop I've ever seen this year, persimmons so heavy the branches are breaking, more pears than ever, and literally tons of walnuts from my trees alone, the deer and squirrels and crows and bears are going to have to sign up with Jenny Craig.
Well, $1395 .00 is close to a samll fortune
>for some folks....
Lee
Moses Yoder
Re: About 4650
Moses Yoder
>I imagine the acorn size varies based on the species of tree, which was not taken into acount either. I read your post and am assuming you are retired and have nothing better to do ;)I wonder if there is a website which gives acorn size of each species?
Dale Lenz
Re: If the acorn is from one of the white...
Dale Lenz
>oak group: plant now. Species of the white oak group germinate in the fall. This is all based on a true white oak, Quercus alba, germinates in the fall. All red oaks germinate in the spring. I'd need to research cold storage and breaking the seed coat to allow moisture to enter the seed to give you specifics. Stratification; cold and moisture requirment and scarification; breaking down the seed-coat.
Re: About 4650
Bill White
>Why don't yo folks get a hobby, say WOODWORKING 'cause you've got way too much time on your hands (snicker, snicker!).
Wher else could one go to fing the correct geometric description of an M & M.
Bill
