tile celing ?
tile celing ?
tile celing ?
Ernie Miller
>I an doing a renovation flip on a 100 yr old house the lath and plaster celing is shot. Some of the rooms all ready have the 12X12 celing tils that are stapled up. so I was thinking about doing that in the dining room. sinse their is lath above the plaster can I staple the tils right to the celing or will I need to run furing strips to staple it to any way? Just trying to save work and money but thought I would ask to find out what every one else thinks.
Re: tile celing ?
Re: tile celing ?
Lee Schierer - McKean, PA
>My guess is that the staples won't hold well in the plaster and you are going to need pretty long ones to reach the lath under the plaster. You also won't be able to tell if the staple hit wood with both legs or found the space between strips. I would do the firring strips and be sure the tile was well anchored.
Lee
Re: tile celing ?
Re: tile celing ?
Ernie Miller
>I have been reading they say they can be glued up? wonder if that would pull down the plaster?
Re: tile celing ?
I wouldn't recommend it
>Our church redid a ceiling a number of years ago in a chapel with 12 x 12 acoustical tile. They glued acoustical tiles to the plaster ceiling. This past winter about 1/3 of the tiles fell off the ceiling without warning. There were four large spots of adhesive on each tile. The glue held, but the tile material failed. We had several more fall since then. I'm not sure how long the ceiling had been up there. we are now faced with a repair and the biggest problem is how to remove the adhesive lumps off the ceiling.
Lee
Re: tile celing ?
What sort of tiles? Tin? PVC? *LINK*
>I'm in the process of renovation my kitchen and think we will install the PVC (plastic) tin-like ceiling tiles. From what I've learned is that there are some that can be glued up, some that cane be srewed up (into exisitng sheetrock) and some that can be nailed/stapled but must have a 1/4" plywood sheets screwed up to the ceiling first (over the drywall).
Perhaps these links and installation info will help.
http://www.americantinceilings.com
http://www.tinceilingdepot.com/
http://www.armstrong.com/resclgam/na/ceilings/en/us/metallaire-metal-ceiling.asp
Happy Woodworking!
Re: tile celing ?
Re: tile celing ?
Fred Davis
>Ernie ,
accoustical ceiling tile has come a long way in design, size , appearence since your ceiling was tiled.
But for stapling , which is the preferred method , you need to nail 1x4 furring strips on 12" centers on the ceiling , also pay attention to the room dimensions so the tile will have the same reveal on parallel walls.
If you put up light colored or white tile , get a box of corn starch and dust your hands with it to prevent marking the tile and you will do fine.
FredD
Re: tile celing ?
Re: tile celing ?-
paul in AZ
>What you put up will ideally be proportional to the historic or aesthetic value of the house.
If the house is merely old and of no other "interest" it probably doesn't matter what you do. If it has qualities that make it worth preserving for reasons other than age alone I'd consider something historically appropriate.
I have had two oldish houses -1908 and 1880 something- and both had a number of cheapo quick fixes done over the years. Eyesores. These had to be ripped out and replaced with something more in keeping with the original design of the structure.
Crumbling plaster is a messy PITA to deal with, hard to repair. But it can be either ripped out or covered over.
If you are not going to replace the ceiling with a relatively historically appropriate material or even plain ol' sheetrock [which is easy to do] then I'd suggest you put up something that the next owner will find easy to rip out.
If the house is worth while someone will ultimately want to do it right.
That plus some eyesore quick fix will detract from the appeal and price you get for the house.
------WebKitFormBoundary91cw+PZc2CQ8ksJe
Re: tile celing ?
Re: tile celing Lemme see....
Justin Szeliga
>Let's take a look at this task. Gonna have find the joists to put up lath every 12" if you want the tiles to hold, can't rely on staples to hold in plaster or to survive the trip though the plaster to the lath still in shape to hold, then gotta put up tiles, 40sq' per carton/$38.00, then need moulding at the edge to cover the joint at the wall.
Or, you could put up 1/2" rock, $10.00/32sq', tape & spackle & paint. Seems like about the same time, less money, nicer look, easier to repair, all around sounds like rocking is the easiest route. That's my $.02
Peace
Justin
Re: tile celing ?
Re: tile ceiling ?
>Ernie, I have repaired a few houses and grew up in one with the Wood lath and plaster.
The plaster does not adhere to the lathes. The laths have spaces between them and the plaster oozes through and curls around the sticks forming "keys" that physically grip the stick. Over time, the keys fails and the plaster separates and falls.
You can repair the plaster by driving screws through it into the lathes. There are discs available that act like washers to help the screws support the plaster. They are perforated so that the sheetrock compound will stick to them.
You can patch the ceiling by cutting pieces of sheetrock to fit into the voids left by the fallen plaster. (Considered tacky by the purists.)
You can screw sheetrock known as "blue board" over the plaster. Blue board is reinforced with fiberglass to give it the strength to help support the failing plaster. This is fast and easy, but drywall is heavy and adds a lot of weight tot he house. If the house has evidence of settling, this may start it settling again.
You could move the plaster, leaving the laths in place and put up the drywall, essentially replacing weight with weight.
If you decide to go with the ceiling tiles, I would recommend screwing the furring strips to the ceiling over the plaster. If you hammer the nails in, you may shake the ceiling enough to loosen the plaster and cause it to fall. You might be able to do it with a nail gun, but that might jar the plaster too.
You could also take the plaster down and leave the laths and staple the tiles to the laths. (Messy)
Re: tile celing ?
Fred Davis
>Lets's see indeed.
"have to locate joists for furring strips", same for sheetrock ,no advantage there.
"Sheetrock is nicer looking", only if you like a featureless flat expanse of sound bounceing drywall which is likely to show joint lines later on.
Acoutistical ceiling tile is just that, sound absorbing, plus it has architecural details, designs , and hidden or accented joints , unlike sheetrock.
Crown mould at the ceiling/wall line looks great regardless of the ceiling material.
Besides all of the above ,it is fun to install , never heard that about sheetrock.
Your choice.
FredD
