What wood is best for printing?
Xeon
>Hi,
I need to print graphics and pictures onto small pieces of wood, so is
pine wood the best?
Does anyone know of other wood which is more suitable for pictures to be
printed on? Any recommendations?
(some wood are not suitable for picture printing due to the nature of the wood)
What about 5-layer birch plywood? I went to Woodfinder.com but got totally overwhelmed by the amount of wood there. I'm not a woodworker so I'm new to all these, but I need to print graphics onto wood.
Thanks for any advice! I'm totally lost.
Xeon
Re: What wood is best for printing?
Dale Lenz
Re: Several years....
Dale Lenz
>ago we "ink stamped" information on some 3"x3"x1/2" wood blocks, carbon storage modules, I believe we called them. The stamped ink ran in the grain of pine. On the hardwoods we use, oak, cherry and others, the print came out fine.
So.....don't know if the above info help you or not(?). Let us know what you find out.
Ken Oakley-Sunny St. Cloud, Fla
>I have had my best luck using well sanded or scraped White Birch and, or Hard Rock Maple.
Plus
>I think I sprayed some lacquer based sanding sealer on the wood before the printing was done
Solid or plywood?
>If I was going plywood, I'd suggest either maple or birch plywood.
If I was going solid wood, I'd suggest a reasonably tight-grained light colored wood. Holly comes to mind (and maple too).
You may also want to look into wood bleaching procedures.
My $0.02
>You didn't mention what kinds of inks you will be using. Some inks, like screen printing inks are quite viscous and will not be so easily sucked into the wood fibers as watery inks. There is also the issue of transparency to think about. You don't want a wood that has features that will telegraph through a transparent or semi-transparent ink. For these reasons, I would suggest a light-colored, hard, close-grained, diffuse-porous wood, possibly rock maple, yellow birch or something similar. On the softer, cheaper side, there are basswood and yellow poplar, although these are more likely to wick the ink and create runs. Whatever wood you use, it would probably be a good idea to coat it with some lacquer or Krylon matte spray beforehand, and then sand back down to the finished wood (or not). The finish will penetrate and seal the surface fibers and reduce the amount of ink that is absorbed.
Experimentation is key here. Woodfinder will certainly help you find sources for the woods I mentioned.
Ellis Walentine, Host
CHERRY!!!
Ron Bauman
>all the old type I've seen had been cherry.
Xeon
>Thanks a lot, guys! One supplier I contacted says that based on his experience, 5-layer birch plywood is best for printing, so maybe I'll go with that.
Btw, for a piece of birch plywood at 4" by 4" by 0.2", it costs US$1.50 per piece. Is that considered expensive? Or reasonable?
Thanks! :-D
Xeon
Xeon
>Oh, and just to add......I'll be using a heat-press and transfer paper to print graphics onto the birch plywood. Sounds good? :-)
I'm concerned about the transparency, though, because there might be a "squarish border" around the image.
Dale Lenz
Re: My last piece of Baltic Birch...
Dale Lenz
>plywood that is approximately 5'x5' by 1/2" was 25~30 dollars I believe.
