>My parents had a set of Ethan Allen living room furniture which they bought in the'60's. Coffee table, 2 "dough box" end tables, and a step table, all made out of ~3/4" maple. Long story short, after some family transitions, I have the panels from these tables (tops, larger side pieces, etc.) which I would like to use for a couple projects. I'm wondering what the best approach to stripping off the old finish would be. To further confuse matters, I had refinished the tops of 3 of the tables when I was a teenager, back in the mid '70's, and I don't recall if I used polyurethane or lacquer. I remember it was a Deft product. Should I use a stripper, if so, which is best & has the least objectionable fumes, or should I sand the old finish off, or is there another approach? Unfortunately, all the panels are too wide for my DeWalt 734 planer, though I may end up having to cut some to a narrower width, depending on what I end up building.
>You might want to order one of the "Circa 1850" strippers from Swing Paints, one of our sponsors. They make a whole range of friendly and efficient strippers for all kinds of finishes.
>I recommend you use a stripper containing methylene chloride. It will be best are removing any type of finish with the least chance of leaving a residue. It will also remove the finish with a single application.
One thing I would check is whether the panels are solid wood or veneer. Much of the Ethan Allen stuff I have seen was veneer over a composition material substrate.
>The cleanest, and by far the easiest way to strip the old surface, is to plane it. Bite the bullet and rip it it in to 12 inch strips on plane a very small amount off the thickness. You will be ready to reuse the wood immediately without the stench and cleanup issues of a stripper chemical.
If you use a plastic sheeting like Saran Wrap over the stripper while it is still wet, you will speed up and imprrove the process , regardless of the type of stripper you use.
