200+ woodworking book reviews
After Market Miter Gauges
Warren E. White
>I am considering an aftermarket miter gauge and have a question that you might help me with.
One of the issues I am concerned with is the maximum width board which can be reliably (with emphasis on that) supported in front of the miter gauge. It seems that if those of you who have such items that you could recommend could measure the distance between the front of the gauge and the blade when the gauge is fully supported by the miter slot I might use that as one factor in my decision.
I assume that saws have varying distance to the blade from the edge of the table. My saw is a Delta Cabinet Saw, but comparisons might still be valid.
It seems in looking at them, some have more goo-gaws behind the gauge than others and may thus limited the gauge-to-blade depth possible when the gauge is fully supported.
Thanks in advance. I look forward to your measurements and recommendations. (I currently have a Smart Miter and although I really like it, the width is limited.)
Warren
Re: After Market Miter Gauges
Lee Schierer - McKean, PA
>Actually, it isn't necessary to have the portion of the gauge behind the cross piece in the miter slot to get an accurate cut depending upon how tightly the miter gauge bar fits in the miter slot on your saw. Your limiting factor is the distance between teh front of your table and the front of the blade. Although I've made cuts with the guide bar and cross piece off the table, my confidence in maintaining a true 90 degree angle is more doubtful.
I recently purchased a Kreg Miter gauge and have been very impressed with it thus far. It appears to be extremely accutate and has several adjusment set screws that will reduce teh slop in the miter slot. On mine I was able to add a .003" thick piece of UHMW tape down one side and the fit is perfect in my miter slot and I get the benefit of low friction. The Kreg cross cut guide has 24" bar and nearly 18" of that are in front of the cross piece so you get a lot of engagement with the table.
Lee
sawing wide boards
Bill Tindall, E.TN
>The best thing for wide boards is a sled. After I finally!! made one (why didn't I do this 30 years ago) I rarely used my Accumiter any more for wide cuts up to 18" or so.
Lacking a sled or for stuff too wide for a sled, I have cut 24" wide stuff best with the small miter. Put it on the saw backwards. Hoist the wide piece onto the table and then up against the backward miter. Using the miter to establish squareness to the blade advance the piece till the miter reaches the back of the saw table. Then remove the miter and stick it into the front of the piece and continue pushing the piece through. It helps to have marked a line for the cut as the piece can be jiggled a bit to keep the cut on this line. I have done this operation lots of times cutting 24" wide plywood. I learned it from a cabinet shop manager in MN many years ago.
It is surprisingly easy to cut 48" wide plywood sheets freehand on the saw. Just don't raise the blade much above the plywood thickness. The massive weight and size of a plywood sheet enables good control of the pieces as they are being cut.
Had I made a sled before purchasing my Accumiter I don't think I would have ever bought it.
>I saw two gauges at the IWF that impressed me. One was the Excalibur/Osborne 50-EB3 miter guide from General (http://www.general.ca/excalibur/pagemach/ang/50_eb3.html). The other was Delta's copy (or similar model) 36-946 Heavy Duty Precision Miter Gauge (http://www.toolsdirect.com/index.cfm/page/product:display/term/36-946/productId/36-946/manufacturer/delta%20machinery).
They both look pretty similar and handled quite nicely. Of course there is always the Incra or Kreg.
A simple crosscut sled
>Instead of the sled pushing the workpiece through the blade, I made this sled so the workpiece pushes the sled. It's a simple yet totally accurate design.
Clint
Jim Dillon
>Warren,
I just measured my General 10 inch cabinet saw and the distance is 15 1/2 inches when the blade is set for roughly 1/8 inch cut, and 12 1/2 inches when the blade is fully raised.
Thanks Bill and Clint for suggesting such a neat concept for cutting wider boards; I will have to build that sled. Like Bill, once I built a regular sled, I seldom use a miter gauge - at least for regular crosscuts. Table saw sleds (I now have three) are unbelievably useful and promote safe operation.
Jim
I Agree--Most of the Time--But Not Always
To actually answer your question
>My Kreg jig has 8" behind the face of the cross piece. The total length of the bar is 24" so there are 16" engaged in the table when the gauge is right at the edge of the table.
Clint; BINGO!!!!!!!!!!!!!!!!!!!!!
Ray Newman
Re: sawing wide boards
Fred Davis
>Why don't you crosscut wide material like plywood using the rip fence?
I would never try that operation you described using the miter gauge backwards unless the cut cleared the blade before the fence fell off of the table, that is a extremely risky way to crosscut on a table saw.
And in shops I have owned and or managed, a cabinetmaker dense enough to try it , would have the possible consequences explained to him, regardless of how many times he had got away with it in other places.
FredD
i've used it for years w/ great accuracy!!!
HC Sakman
BILL White
>I use the Incra SE on the TS, but this subject is also the reason I keep the RAS tuned up.
Bill
Fred Davis
>Right
FredD
Re: One of many
Jay St. Peter - SoMD
>I use a Jointec SmartMiter when it works. But there are a number of situations where it doesn't work. Sometimes, the work needs to be on the table instead of a sled. Thick pieces and dado blades come to mind. For that, a high quality miter gauge is indispensable. I have an Incra 1000. Also, when the blade is tilted. Either a quick/dirty sled or the Incra for that. Finally, when the piece is wider than the distance from the edge of the table to the blade. For that, I have a sled like the one shown above. The difference is mine is longer and will crosscut up to 36". The Jessem Mast-R-Slide looks like a solution to all the problems, but with a price.
