glueing over poly
glueing over poly
glueing over poly
Denny Mercer
>I am building the bedside table as presented by Sandor Nagyszalanczy in October's Woodworker's Jouranal. Sandor "finished" the table before gluing. I have heard that glue will not adhere to polyurethane. Can a successful glue-up be accomplished after having coating the parts with poly?
Thanks for any body's help...
Re: glueing over poly
>Hide glue might work, but I wouldn't trust Titebond.
Clint
Dave Anderson (PacNW)
>Try Titebond Melamine glue. I did the same thing on a magazine rack 20 years back. The rack is as solid to day as when it was built. This has been my go to glue for weird situations ever since.
Denny Mercer
>Thanks, Clint, for the quick response. I agree that Titebond glue would be suspect over poly. Consequently, I will glue the thing before applying the finish.
Best regards,
Denny Mercer
Denny Mercer
>Well, Dave,
You have given an alternative suggestion that will depend on my finding melamine glue (my ignorance is complete, having never heard of melamine glue). I will try to find a source on the Internet.
Thanks a lot,
Denny
What's wrong with taping over glue areas?
>That way you could finish it without any trouble and then glue it with the glue of your choice.
SSSSHHHHHUUUUUSSSSHHHHH, JL
>Good Evening JL,
That is exactly what I'ce done a zillion times. Never had a problem. I'd hate to ruin anyone else's fun, though. Maybe we should keep it to ourselves. :<)
George
Re: What's wrong with taping over glue areas?
Denny Mercer
>This, too, is a good idea that never entered my mind. Thamks, a lot.
Denny Mercer
melamine glue
Ken Platt (Granby, CT)
>Another brand is called RooClear. I got a bottle at Woodcraft. Surprisingly easy stuff to work with. You'd think that anything that would stick to melamine would have to be nasty, epoxy-like stuff. It's water-base, easy clean up, works well on melamine. Never occurred to me to use it in the situation described, but might make it easier to make the finish first/glue first decision.
Ken
Jim Dillon
>Denny,
Usually, I interpret "...finish before glueing..." as meaning that the areas where glue will be used are devoid of finish - thus giving a much better bond. As mentioned, tape is used and must be pressed down really well to minimize seep of finish under the tape. Some seepage probably will occur, but, hopefully, enough unfinished wood will be left to give you a good bond. This is kinda a trade-off decision. In some cases, the decision is somewhat clear like panels in doors, complicated and hard to reach places etc.. But in other cases, the labor of taping everything off may not be worth the effort of just biting the bullet and spending a LOT of time applying the finish to the assembled workpiece and then (in some instances) a LOT of time wiping if off. I guess I try to examine the preassembled workpiece and try to imagine how difficult it would be to apply finish (using hand, brush, wipe, or spray) to all areas of the workpiece. That will dictate to me if I need to tape joints or not. Personally, I have done far more prefinishing of door/carcass panels etc. than any taping of joints. Any taping that I have done is actually to catch any glue squeeze-out - especially on the inside of boxes.
Jim
I don't think so!
Lee Schierer - McKean, PA
>I have an outfeed table on my TS that sometimes doubles as an assembly table and has been known to get drops of glue on the surface. Once the glue dries, it will pop off rather easily without leaving a mark on the surface.
As others have mentioned, cover the areas to be glued with tape before applying the finish. Regular masking tape does a better job than the blue or purple painters tape, but cannot be left on for long periods of time. Leaving regular masking tape on formore than a couple of days will make it very hard to remove.
Lee
Re: melamine glue
Fred Davis
>I got the new cabinetmaker issue yesterday and the letters to the editor had that exact same question and the resident glue guy said white Roo Glue was the way to go.
FredD
Re: Use white 3M masking tape (easy release)
Alex Grigoriev
