Front load washer/dryer - - ideas on a platform?
Pete LaBelle
>We purchased a new front load washer/dryer set this past spring. Opting not to spend $400 for the spacers that elevate the machines, it has been decided that it was a bad decision, but still fret on spending the money, thus we are now comtemplating building a riser system for our machines.
Has anyone built such a thing? Wondering what ideas worked or didn't work for you?
Thanx !
Pete
Re: Front load washer/dryer - - ideas on a platform?
2 x 8s
Dustmaker Mike
>When I bought mine a few years ago they gave me the pedestal for them. With that said it is nothing more then a few 2 x 8s in a rectangle with a center brace. They used blocks in the corners to place the machines on. Also they have adjustable legs on the bottom as well as the one on the machines. I would cup the place where the machines sit so the legs will not slide around. Hope this helps
Re: 2 x 8s
John Veerkamp, Western Mo
>Caution, front loaders do bounce around more than top loaders. make sure the platform is secured down and that there is a lip around the edge to prevent the washer from jumpimg off.
John
Ray, SW Ohio
>When we bought our front loaders, we did not buy the pedestal either (too expensive). I ended up finding some on craigslist.org for $100 for both of them. Thought about building them but I found someone that did and they said it made the sounds the washer makes (like in spin cycle) quite loud. I would shop on ebay and craigslist for some first. My 2�.
Re: 2 x 8s
>We got a deal which included the pedestals with the washer and dryer so I didn't have to build them. As mentioned, there can significant vibration from the washer since it spins like a turbine. Unless bolted to the floor, it may well move a bit. I would take a hint from the pedestal maker and fasten the pedestal firmly to the machine, then use shock pads on the floor. I think one big pedestal for both machines might be better that two smaller.
I placed some 4" foam blocks between the washer and dryer which greatly reduced the vibration. Based on that experience, I'm thinking of constructing some sort of shock absorbing connection between back of the washer and the floor.
BTW, the commercial pedestals have drawers which are great for storing things but a little too short for the detergent bottles we use. If making pedestals, I'd probably make them a little taller with rollouts for storage.
(These are the best laundry machines we've had in our 38 years of housekeeping)
wrf
>just build a deck. simple framing . dont need 2x8, 2 x6 or even 2x4 work fine. We are talking a really short span for these things. establish the best height from the person that uses it most. My wife has a bad back and I have made these for frontloaders in each of our homes. No big deal and i would never buy the pedestals; if you change washer/dryer down the road, might need a new pedestal but a deck will always still work
