Angle cut
GarryF
>I'm building a corner cabinet and need to cut a board 56 inches long & 39 inches wide so the two sides fit in the corners. What is the safest way to cut this on a table saw? Or is there a better way?
Angle cut
GarryF
Re: Angle cut
Kneale Brownson dreaming of snow in N. MI
>Do you want to end up with two 18.5 inch sides? These will be the back of the cabinet and hidden in a room corner? If so, I'd rip the board on the table saw so that one side's width would equal the other side less the thickness of the board and butt the more narrow piece against the full width one. In other words, from your 39-inch board, if it is one inch thick, I'd cut it with the blade at 90 degrees and make one piece 20 inches wide less half the blade kerf and the other 19 less half the blade kerf. Much easier joint to make than trying to make the sides equal and putting a 45-degree bevel on each.
Re: Angle cut
Gene Gauss
>Keeping to a line on a table saw with a piece this large would be a bit touchy, unless you have a very wide table and fence travel. Trying to feed it through freehand with a smaller table could give unacceptable inaccuracies. I have a very good circular saw (Porter Cable Framer's Saw), and for cuts like this, I clamp a straightedge to the sheet goods, offset from the cut line by the distance between the edge of the base of the saw and ride the base of the saw against the straightedge. With a good blade in the circular saw, I can get pretty accurate finish cuts. Make sure you get the corner angle right. Sometimes you'll find a corner that's not square, or the buildup of taping compound in the corner will cause a gap if the cuts are straight. Consider templating the corner if it's a bit off.
