wd 40 straws and caps
les winter
>Where can I get replacements for the straws and spray caps that fit wd 40 cans?
thanks
Les
les winter
thanks
Les
Same place that you can find
>You can find those WD-40 straws in the same place you'll find all those odd socks that get lost in the washing machine.
When you find them, PLEASE let me know. :)
Happy Woodworking!
Re: Same place that you can find
Dale Lenz
>Easiest solution is to purchase another can of WD-40. I put a rubber band around the can for the straw holder, works for a year plus.
Re: Or *LINK*
Dale Lenz
>See link below
40 WD-40 straws
Re: Or
les winter
>My Hero!
Re: wd 40 straws and caps
IEW
>Quit using WD40, it attracts dust! You will never find a can of WD40 around an airport. I use LPS it comes in 3 flavors and is superior to any others.
Pack rat drawers
Tom Dunlap
>Any time an aerosal can is emptied it's nozzle and straw get pulled and filed in my plastic drawers cubby. There has been more than once that I've found a odd clogged nozzle but there is another one in the drawer. Rattle can paint nozzle dip tubes are cleared by inverting and spraying then the nozzle goes into a small container of thinner to keep it clean.
Justin Szeliga
>I always cut the straw in half, rarely needing the whole thing, & stash the unused one in my truck in a tool box. It seems the shorter tube is less likely to get knocked off. Then when the one on the can disappears I've got another to use. & I never throw them away, so they do build up after a while. Even have some whole ones around for when I need to jamb the tip in close to something.
Peace
Justin
Danny Julian
>I have found that the plastic shaft of a Q-Tip works quite well as a replacement straw. You can also leave the cotton on one end to swab rather than spay the WD-40. Caution! Please do not use the Q-Tip to clean ears while still connected to the can.
