REAL MILK PAINT
OT Help Computer guys... Help!
>I have screwed up. I have a PC running XP Home Edition. An update came in for Service Pack 3 and I tried to install it. It took a very long time, maybe an hour and then said it had failed and would now undo what it had done. That took another long time and then said the install was only partially complete and that Windows may not operate properly. In the midst of all this Norton came up and said it no longer protected my E_mail. There was a message to uninstall it and start over. I went to the Add/Remove feature in Windows but it was so slow and appeared to never load the list of programs. I closed that and tried the Uninstall feature from Norton that has had an icon on my Desktop since forever. After a long pause it said the feature had expired.
I went back to the Windows Add Remove feature but nothing happens.
What should I do? Should I go to Microsoft and download and install Service Pack 3 completely? How do I do that? Is there a back up step available in XP? How do I get the E-mail protection turned back on? Please keep this simple, I'm over my head.
Re: OT Help Computer guys... Help!
Bruce, a MN Galoot
>For starters, I'd try the system restore feature. I've screwed up worse and the system restore fixed it. Go to Start, All Programs, Accessories, System Tools, System Restore. Pick the last date that your computer worked properly and you should be good to go (with any luck).
Bruce
Dave Anderson (PacNW)
>Zone Alarm posted version 8, this trashed countless systems. They recalled it and told everyone to reveret to the previous version. That was over a month back, still no fix. First, before upgrading, go to system restore and create a new restore point. Second, disable all anti-virus programs before upgrading. Virus programs often interfer with software upgrades. Third, after installing ALWAYS reboot the system, then run a virus scan. If there are any problems with any program or if the system runs slow, do a system restore at the point you created.
Advice worth the cost (zero)
Alexander Grigoriev
>Get rid of Norton (Symantec) Antivirus; this is the most unstabilising piece of software. You don't need it if you use proper security configuration on your computer: separate Administrator account and other "Limited User" account(s) for everyday work.
del schisler
>Do you do a disk clean up ? and also disk defragmenter? This should be done from safe mode Do you know how to get to safe mode? If not post and i or someone will tell you Their are a few things to keep comp running good and clean I been in computers for probly 19 yrs I don't say i am a perfecto But don't have any problums I use AVG which is free And CCleaner also free And Spy Bot which is free Than AdAware which is free Their are some others But i like these The first thing i would do is go to quick restore and restore to the next point that would be behind the date that the last item was down loaded this will get the comp. up and running Than i would go to the Safe mode and do the clean up and defrag Than while in safe mode Click on my comp.Icon and right mouse click Than down to properties Than see if their is a check mark in system restore If their is than your system is not monitoring Do your system restore first Than after you are done with that take the check mark out Than your system will be monitoring your restore point's Do your virus scan's now This is so that a virus cant get back into the system Than once you are back to the desk top Dont forget to take check mark out of system restore so it is monitoring again I do the disk clean up and defreg at least 2 times a mo. good luck del
Bill Howatt
>This link should take you to where you can download SP3:
http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en
If it doesn't work Google for XP SP3 Microsoft and follow the links at the MS site to get to the standalone version. It is a 316MB download so be prepared.
Howard Norman
>I would agree that Norton AntiVirus is not the best but I would hesitate to recommend that anyone not have AntiVirus protection on the computer. I use, and recommend, AVG Free myself.
