Coffee vs. wood
Coffee vs. wood
Coffee vs. wood
Thad
>The project is a coffee container with compartments for various flavors (imagine a small filing cabinet). It will hold both beans and grounds.
The issue is that my FIL has claimed that there reactions between coffee and certain woods that I should be wary of. This was news to me. I told him that I figured staying away from exotics was wise with this application, but was unaware of his claim that the acids or oils of coffee and wood could be problematic.
Anyone have any insight on this. I would rather learn from him than be proven wrong by him.
Trying to keep my pride ~ thad
Re: Coffee vs. wood
Dale Lenz
Re: Coffee vs. wood
Dale Lenz
>Wood can impart flavor for many items: booze, tobacco etc. Someone has not came up with a positive for wood and coffee, at least it has not been published to my knowledge. So for now I'd keep coffee in a light and air tight container of ceramic is ideal.
Re: Coffee vs. wood
Dale Lenz
Re: But..., then again
Dale Lenz
>wooden cookware is often made out of beech, imparts no flavor(?). But, certain beers are beechwood aged. You need to research wood imparting flavor/odor. Let us know what you find out. Dale
Re: Coffee vs. wood
BILL White
>Don't think it'll be a good idea. You will get some transfer with any wood. Least likely to offend would be maple, but there could be some even with that.
Certainly don't want to use any resinous wood, and no finish at all.
Bill
Re: Coffee vs. wood
Re: Coffee vs. wood
John Luke
>Kentucky coffee bean wood
Re: Coffee vs. wood
Re: Coffee vs. wood
Bill Earl
>Dale has the right idea. You want to protect the coffee from air and moisture too. You might consider designing the drawers around some airtight canister.
Re: Coffee vs. wood
Re: Coffee vs. wood
Tony - Memphis
>I don't know about the flavor/reaction thing. But, what I might do is pick a standard sized Reubbermaid or Tupperware container and build around it. Make rabbets to hold the lips of the containers, etc. nice thing about that is you can wash the containers too. Coffee is surprisingly oily. Let us know what you come up with.
Tony
Re: Coffee vs. wood
Green or Roasted?
paul in AZ
>I buy green beans and roast them at home. With no direct experience of storing in wood I suspect that a partial answer would lie in green vs. roasted beans.
Green beans look like dried green peas, are shipped in burlap sacks and often have a strong smell of the burlap. This goes away in the roasting process. Green unroasted beans can be stored quite a while out in the open without deterioration.
Roasted beans have had their oils released and as such are amenable to absorbing flavors. It doesn't take much extraneous flavor to affect coffee. Test that by putting just 3 or 4 perfumey "flavored" beans [yuk] into your grinder with unflavored beans. That small amount ruins a batch. My point is that even a tiny amount of wood flavor would be absorbed by roasted beans and affect flavor.
Roasted whole beans begin to lose flavor in a week or two and are ideally stored in a sealed container +/- keeping them in the freezer. Unless you go through a huge amount of coffee I can't imagine storing roasted beans in wood on your counter top.
Once ground, coffee starts to go flat in a week. A sealed container and cold delays that.
If you buy whole roasted beans, grinding them fresh for each batch is optimal. No point in storing it as preground coffee.
So, if you are a home coffee roaster I'd guess that storing green beans for a while in wood would be OK but I look at storing roasted beans that way with suspicion.
Re: Coffee vs. wood
Re: Coffee vs. wood
Ray Binnicker
>Thad,
Build the cabinet, and drawers out of the wood of your choice. Size the drawers to hold containers with sealing lids to keep the coffee in. I've seen nice stainless steel cans with lids that should keep the coffee fresh.
Ray Binnicker
Re: Coffee vs. wood
More than you want to know ,
Michael Dresdner
>Some woods will indeed impart flavor to coffee (and cigars), while others won't. However, if you finish the interior with a good barrier coat such as dewaxed shellac, that will usually block the odor transfer. As a Seattle area coffee snob, I can tell you that no one I know around here uses raw wood coffee containers.
Of course, the serious among us buy coffee roasted that morning. Anything not ground and brewed that day is kept in the freezer in an air tight container. And yes, I know some people who roast at home each day, grind just before each use (using only a burr type grinder, regularly sharpened), and will only drink a pull cupped in under twenty seconds. My favorite shop cups in under ten. Some locals are SERIOUS about coffee.
Sorry, I realize I just used coffee lingo in that last sentence, and should translate. Here's a very abbreviated coffee glossary.
A pull is a shot of espresso. Cupped means it is served and handed to the person who is to drink it, either as espresso or in a mixed drink such as a latte or flat white.
A latte is espresso with steamed milk and a modest amount of foam. A cappuccino is the same basic thing with mostly foam and a small amount of milk. A flat white has no foam at all; just steamed milk and espresso. Other iterations include con panna, macchiato and Americano, to name just a few.
Sizes are equally curious. Short is eight ounces. Tall is twelve. Grande (Italian for large) is sixteen, and Venti, which is the Italian word for twenty, is, yep, you guessed it, twenty ounces.
Now, wasn't that way more than you ever wanted to know about coffee mania?
Re: Coffee vs. wood
Sanka You, Michael
Re: Coffee vs. wood
Hey, you're latte than usual with a repsonse
Re: Coffee vs. wood
Re: More than you want to know ,
Bill White
>I think I just got a headache.
The learning curve in my life is rising too rapidly.
Give me a double shot of something!!!!
Bill
