Festool circular saw
>Anyone use the Festool circular saw? Worth the money?
I see they have a 6-1/4" and an 8-1/4" saw with a longer guide rail.
Opinions welcome.
Re: Festool circular saw
>I have a Bosch worm drive that does everything Mother Nature intended a circular saw to do, and it performs excellently. An 8 foot cutoff from a sheet of 1/2 in ply makes a servicable fence; as do 5 foot and 3 foot pieces of angle iron. My needs are covered for sizing paneling or wide glueups. Final dimensioning and much jointing is done on the table saw or with the router. IMO the exorbitant price of the Festool isn't justified.
Clint
Ted Owen, Pittsburgh
>I have the smaller one, as that size works well for reducing plywood sheets.
It's worth the price to me because of how it integrates with the Festool system--guide rail, MFT, etc.
Best, Ted
Vijay
>I have one it it makes cutting sheet goods a pleasure. Also straightening a bent board (as in edge joining).
As mentioned the smaller one is adequate for sheet goods, but the larger one is nicer for 8/4 lumber --lots of power.
The cut quality is so smooth and there is a riving knife, and you can make plunge cuts and the dust collection with a vacuum is superb--I can go on.
In short if you can swing he dough it is a great saw system.
Vijay
Kris Lasure
>I second what Vijay said. I don't use mine everyday, but when straigtening up long lumber or knocking down sheet goods, I wouldn't do without it. I actually bought mine for solid surface work, but find that it comes it handy for other duties as well.
If you got the $$$, I'd recommend it.
kl
Chuck in ND
>$475 and $595 for a circular saw ? Thats a little extravagant for me.
guide rail?
>Thanks. I have their router and edge guide.
For those that have the smaller saw, is the shorter guide rail a problem? I see the bigger saw comes with a longer rail. The smaller one is lighter as well which seems to be an advantage. (I do have other circular saws for framing lumber.)
Binen
>I never thought they were worth the money they cost...Until I bought one. Now I kick myself for not buying one sooner. I'm not saying everyone should have one but if you breakdown sheet goods much they are worth it. It is a well made quality product.
Binen
Decisions, decisions...
mdclor
>A second circular saw or 100 bf QSWO????
Re: guide rail?
Jay St. Peter - Southern, MD
>Out of all my Festools, the saw and sander are the ones that I find most worth the money.
The 55 guide rail is reasonable for cutting 48" sheets, but has to be positioned pretty well to give you the extra overhang to start and finish the cut with the saw still on the rail. The larger saw makes this even tighter, especially on MDF which tends to be 49".
For longer cuts you need a longer rail anyway. I have two 55"(1400) rails that I connect together to make 8' cuts. I'd prefer to either have a 75" or 112" rail as my second rail. IMO, a second rail is necessary, so just get something longer if you get the smaller saw.
As mentioned earlier, the small saw will barely deal with 8/4 from a depth perspective. I personally think it has plenty of power if you use the right blade. But, the depth of cut from the rail will barely make it through surfaced 8/4. It won't make it through rough boards to hack them down for jointing. OTOH, they have a dust cover for the smaller saw. Combined with cutting on a foam sheet makes DC nearly complete.
Jay
Re: guide rail?
Chad Pearson
>I guess the length of your rail depends on your needs. I only have the short rail but I don't often need to rip a piece of plywood along its entire length. If you build items like a tall bookshelf out of plywood you might need a longer rail. For me I seldom use lengths longer than 4 ft. Plywood sheets usually get cross-cut first. The few times I've had to rip a longer board I just go back to my table saw.
I enjoy the size of the smaller saw. If I thought I needed a longer rail I would just buy that separately. In my opinion the larger saw would only be needed if you tend to cut thick stock frequently. The smaller saw will cut 1 15/16 inches when using the guide rail. The larger saw will cut through 2 3/4 inch.
Since I have bought the Festool (and MFT table) my tablesaw and SCMS usage has gone down dramatically. About the only thing I use the tablesaw for anymore is dados and ripping. Crosscuts of boards and panels gets done on my MFT table.
Well, if it takes food off the table or cuts into the college fund, I guess so. But I've never been sorry buying good tools and from what I've seen, the Festools are top of the line. I already had three routers on hand including a good PC but I'm impressed at the Festool design and operation.
Chuck in ND
>I've got no problem spending money on good tools also, believe it or not I do have a couple, I've been a woodworker for about 25 years, so I do know the importance. The thing is I'm not a rich woodworker, especially nowdays, so I need to spend my money wisely. I'm sure Festool makes good tools, however I think some of the claims people make are stretched a little. Recently in another forum a guy was deciding on what type of tablesaw to buy, then at the end of his post says, that he will just buy a Festool circular saw instead. Well comeon, a circular saw isn't going to perform all the tasks of a tablesaw, it's like saying a hand drill will perform all the tasks of a drill press. Like the SawStop, if you can afford it, well good for you, not everyone can.
Jesse Cloud
>Two good reasons for my Festool circular saw - my back and my lungs. I set up saw horses with a few old sacrificial 2x4s by the garage door. Pull the truck with the plywood or mdf right up there, slide out the ply onto the horses and make the final cut right there. When I first bought the saw, the idea was to break down the sheets and go to the tablesaw, but I quickly found that I can make as precise and clean cuts with the Festool as I can with the Unisaw, and with a lot less lifting.
When I was cutting MDF with the DeWally, the garage was always a cloud of mdf dust, with the Festool, I cut 5 sheets and swept up maybe a teaspoon of dust - probably saved half an hour in clean up time.
Yeah, you can use a stick of angle iron to guide a circular saw, but it can drift if you don't watch it carefully. The Festool guide rail captures a channel in the foot of the saw so no drift is possible.
The price is steep, but you know I don't remember what I paid for the Festool saw, but I curse the $100 I spent on that darned Bosch colt that scrapes my knuckles every time I change bits.
Chuck in ND
>Jesse, if you had bought a good dust collector instead of that circular saw you would not have all that dust from the DeWalt and alot of other tools in your shop. As far as the guide rail goes, most people use a good fence on the tablesaw, with your Festool circular saw you have to reset the your guide rail and square it for every cut. Sorry, but I don't buy the replace your tablesaw with a Festool circular saw gimmick.
Re: Festool circular saw *LINK*
Chuck in ND
>Actually a more affordable solution would be the Portable Panel Saw System 2.0 that is sold by Penn State Industries.
http://www.pennstateind.com/store/PPS-2.html
>Thanks, Chuck, that rail looks nice. I'm not worried too much about the cost - these tools are all just play toys anyway. I was intrigued by some of the Festool features such as the plunge cut.
Re: check out the newTrack Saw from DEWALT
Dave Anderson (PacNW)
Chuck in ND
>$500 - $1000
See it on YouTube *LINK*
>http://www.youtube.com/watch?v=ggy_3aQnCDU&eurl=http://www.stripersonline.com/surftalk/showthread.php?p=5203071
Happy Woodworking!
Hmm, looks a lot like the Festool
