Porter Cable 690 Thumb Screw
Tomm
>I find it is becoming difficult to tighten the thumb screw on the PC690 router every time I raise and lower the bit. I was wondering if anyone has changed or modified the thumb screw to make it easier to turn. Thanks for your comments.
Re: Porter Cable 690 Thumb Screw
Carol - now back in Dubuque, IA
>I use a ratchet lever with a 5/16" threaded stud. It turns into a 5/16" square nut. A Delrin space separates the lever from the 'ears' so it is easier to turn. Hard maple could be used as the spacer in place of Delrin plastic.
You can see pictures in my book, "Router Joinery Workshop."
Bicycle quick-cam nut
Re: Porter Cable 690 Thumb Screw *LINK*
Rob Stokes in North Vancouver
>I adapted one of these to mine - no going back
cam clamp
Wooden Oak Wrench
George@Colonel's Workshop
>Good Evening Tomm,
I own several PC 690 bases which are thumb screw. I dislike that feature immensely. I made several wooden wrenches which capture the thumb screw and permit it to be tightened easily for proper set up. I've used these for a number of years with success. A couple months ago, somebody gave me a very beat up 690 LR which had the cam lever and I swapped out that bass for use with my D-handle 690. Its really fine to work with, and much more convenient than the wrench, which is pretty inexpensive and very fast to make from scrap. Normally, I would recommend a simple wooden wrench as a solution to the problem. But having seen the Lee Valley offering above, I think I'll acquire a couple of them and retiure the wrenches. Anything is better than the stock thumb screw, but the cam lever clamp is pretty slick and fairly cheap.
George
BILL White
>Replace it with a cam clamp. You won't be sorry.
Bill
Pat Warner - check his site for practical solution
Howard In Toronto
