BLO redux
BLO redux
BLO redux
>In the earlier discussion re BLO, several posters extolled its virtues as a gun stock finish, so I asked a friend who custom makes multi-$thousand stocks what he uses. Not BLO. His choice is either Waterlox or Helmsman Spar Urethane. While formulation information is not very forthcoming from the manufacturers, Waterlox appears to be based on tung oil and Helmsman on urethane and (my guess) soya or tung oil.
As an aside, his finishing schedule involves multiple wet sanded coats of the thinned finish to fill pores and build a thin film with a final rotten stone rubout.
Clint
Re: BLO redux
Re: BLO redux
jerry mayfield
>You have both ends of the spectrum. Waterlox is a phenolic resin tung oil varnish and is very good. Minwax HELMSMAN SPAR POLYURETHANE is a urethane resin linseed oil varnish and is one of the less than good ones I have used or seen used.
Regards
Jerry
Re: BLO redux
gun stock finish
Bill Tindall, E.TN
>Nobody hunts with a multithousand dollar stock so what is used on these museum pieces is of little relevance to a utility gun. One could make a case that they should be finished with shellac or lacquer like other museum pieces.
For those deciding on a finish for a gun that will actually be used, consider the two shotguns in the picture. Both these guns have traveled hundreds of miles in the field under all sorts of conditions. The double was my fathers and I prefer to hunt with it. The pump was my great uncle's and while he hunted with it a lot, I haven't hunted with it as much. So it has been in retirement since mid 1950's.
The pump has what is left of its varnish or lacquer factory finish. And it has suffered the typical fate of such finishes- scratching, getting clouded by water and generally falling off.
The double was refinished in the mid 1950's with linseed oil and I have reapplied a dab, now and then, though not in recent memory. I have shot hundreds of rabbits with this gun, some ducks and other flying food, and carried it hundreds of miles in the field since refinishing it 50+ years ago.
BTW,I oil my canoe paddle shafts for these same reasons.
More BTW, under the guns is a test piece of crotch mahogany. The right side will be finished as recommended by Alf Sharp with a schedule that includes a linseed oil step. I'll post the results when it is done. If you question Alf's authority in these matters go visit his web site.
Re: BLO redux
Re: gun stock finish
Fred Davis
>Linseed oil is the finish on most of my guns and it as Bill points out is a friendly finish for outdoor firearms.
Using a shotgum for Rabbits , Gee Bill your like my brother who once said " I never could get them to stand still long enough for a .22"
FredD
Re: BLO redux
Chuck Kettler Greenwood IN
>You have not met the guy with the zebra wood Weatherby 300 Mag or perhaps the boat builder with the top of the line Baretta SG out in the field. To people who have too much money they have to do something stupid with them dollars.
