Jessem Mastr Slider
Jessem Mastr Slider
Jessem Mastr Slider
howard
>Bought it 1 year ago to mount on Delta Contractor saw. Never did. Contractor saw broke on move to new shop. Bought new PM2000. Slider won't fit, fence rails are in the way. Anybody want a never used one for $300+ship, or any ideas on how to make it work. Thanks
Re: Jessem Mastr Slider
Howard Norman
>I am not familiar with your particular saw but I would suggest you look to see if you can't cut the fence rails to accommodate the Jessem.
Cut to be able to re-join *LINK*
Garrett in Victoria
>Hi Howard
If you read my article at the link below, there's a section on cutting the Unifence rail in a way that you can later re-join it. I see no reason why you couldn't do the same for your PM.
Cheers, Garrett
Cutting the rails and re-joining them later
Drill new holes in the fence guide rails?
Ray Newman
>One time I had an Excaliber (or an Exaktor??) sliding table mounted on my Uni-saw. The directions advised to cut the guide rails.
Instead of cutting the guide rails, I simply drilled two additional holes to shift the fence to the right, then install the sliding table. When I removed the table, I moved the fence rail to its original position by utilizing the original holes.
This seemed to me to be a much neater & easier way to mount the sliding table than by cutting off 8-10" of the fence
guide rails
Thanks for the advice.......
howard
>I will try first moving the fence rails over to avoid cutting them. If that doesn't do it for me, then I will likely use a sled. Thanks again.
