Motorhome cabinet repair
david brady
>Folks,
I have a high end motorhome (Blue Bird, Wanderlodge), with a maple interior. I have two questions. First, I can't locate a source for the Valspar stain used on the cabinetry (Valspar American Traditional Gel 95927 Fruitwood). Second, over the years the cabinetry has accumulated it's share of knicks, scuffs, and cuts. The original finish is lacquer. I'd like to do some spot repairs with shelac. What is the best way to spot repair this type of finish? Much of the wood is solid maple, but I have my share of maple laminate on plywood substrate. Over the years the laminate has checked. Is there a shelac solution for checked laminate. Maybe I'm thinking of shelac as too much of a cure all!
Thanks,
David Brady
NC
Re: Motorhome cabinet repair
Dave Bair, Eaton Rapids, MI
>Sorry no one has gotten back to you more quickly.
Valspar products are carried by Lowe's, at least in my area.
Shellac is easier to repair than a lot of other finishes because each new coat disolves and rebonds with the previous layer. However, I have no experience or information on it's use for spot repairs with other types of finish. The alcohol solvent in shellac will probably not disolve lacquer with it's tolulene (I believe) solvent base.
I do know that shellac will bond to most other finishes, including lacquer, so you could do a full recoat with shellac and be fairly confident it will adhere well. However, this is not a spot repair, it is a complete recoat.
One of the finish vendors (I think it's Homestead Finishes)has a bulletin board where a variety of excellent finishing advice is available. You might get better info there.
