>Norm uses a lot of MDO and MDF. However, one of them he specifically states is terrific for outdoor use when painted. He even goes to say that municipalities use this (whichever one it is) for highway signs.
Once you guys (and gals) give me the answer, can you tell me if this would be suitable to run a 3/4" roundover bit and then cut my own quater round and use it (for example) in a bathroom where moisture is sure to be present at one time or another. I am also construction some garden hose holders and they would for sure be subject to weather/moisture.
As always....thanks in advance for your valued advise.
>MDO (Medium density overlay) is a plywood product with a resin impregnated paper (not sure what kind) overlay on one or both sides. It is very weather resistant, and yes it is used for highway signs. I go through about 30 sheets a year where I work, for signs exposed to extreme winter weather conditions. I also use it for the substrate on any cabinets or countertops that may be exposed to water.
MDF (Medium Density Fiberboard) is in my opinion a high class particle board. In all honesty I have never used it.
MDO and hose holders should be OK, paint the edges. Homedmade 1/4 round, neither, MDO = Plywood, MDF not water resistant enough for me. I would use solid wood
>Up here in the Great White North, we can also buy exterior grade MDF. It is brown, not grey like MDF. The glues and sealers in it are much more resistant to water and moisture. I've made scuba tank racks and other boat parts from it and it is holding up well after 5 years of splash.
MDO (Medium Density Overlay) is a standard multiply plywood made with exterior glue with a resin impregnated paper overlay applied to one or both sides. It's original intent was for making outdoor signage. It's an exterior rated product but used outdoors, the edges must be sealed or will rot and delaminate over time.
MDF (Medium Density Fiberboard)is a product made from finely ground wood chips that are mixed with a binder and then pressed into sheets. It is quite dense and heavy. Much interior trim is now made from MDF rather than solid wood.
There should be no reason not to use MDF in a bathroom provided it will be painted. It's not like it will fall apart in a bathroom. MDO is the wrong thing to us for trim.
>Howard put his finger on it: MDO is plywood. If you want quarter round trim that is impervious to moisture (or at least doesn't rot), try some solid Spanish cedar or cypress. There are other durable woods that are probably too good for painted trim, such as teak and genuine mahogany. But, if it will be painted, any old trim wood should do the trick. Poplar, alder, even pine.
On another note, I've never had MDO delaminate, although I will take Howard's word for it. I sheathed the outside basement door of my old shop with MDO about 30 years ago. When the barn burned down in '98, the MDO, without so much as a coat of paint, was still solid, although the faces had acquired a certain mossy patina from being on the outside of a bank barn.
MDF, OTOH, is very bad news in wet environments, as it swells and self-destructs if water gets to it. For flat work, if you seal the edges well and paint it thoroughly, you can dodge the bullet for a while, but I'd recommend VC ply rather than flake or fiber board. Definitely don't bother with MDF for moldings. To me it is a substrate for veneer or paint.
>There is a product called EXTERA. Outdoor grade of fiberboard. Used it on our home for outdoor craftsman-styled columns. Very dense stuff. Put it up, paint it, forget it.
