A55 Smoothing Plane
Cedar Chest Finish
Cedar Chest Finish
Cedar Chest Finish
Clementine
>I am making a cedar chest from very old 1x6s that were put laterally in a fence for about 30 years. The "old wood" look is definitely there, but I think the cedar aroma is about gone. I want to finish with clear shellac instead of Danish oil to give the wood a lighter finish. If I use some cedar oil to restore the aroma, when do I apply it it - before or after the shellac?
Re: Cedar Chest Finish
Apply Finish Only to the Outside--Chest Exterior
>Good Evening Clementine,
I assume the planks you will use are cedar, and that you are not planning to use another specie for the carcase and line it with cedar. By itself, cedar is a beautiful wood, and it takes finishes nicely. Youy may finish the exterior with suitable top coats, but leave the interior alone. Sanding your planks first and before construction, will restore the aroma. Cedar oil, if you need to apply it, should be done over unsealed/unfinished cedar to be effective. The attached pix shows one which I made for my wife. I used shellac and wiping poly as a top coat for the chest, which is cedar and curly maple. The interior is unfinished, and has plenty of natural aroma. See Shop Shot 746.
George
Re: Apply Finish Only to the Outside--Chest Exteri
Clementine
>Thanks for your response. The chest will be entirely of the old cedar. I plan to use clear shellac only on the exterior as you suggest. I don't know about the aroma yet, but I can always add a little cedar oil later on the interior if needed. Your chest in Shop Shots is very beautiful. I'm sure your wife is very proud of it.
