Thank you Mr. Tindall
Denis Ch�nard, Orl�ans, Ont.
>White glue works great with veneering that brittle veneer of mine! I would never have guessed...
Thanks again for the tip,
DC
Re: Thank you Mr. Tindall
sources of sage advice
Bill Tindall, E.TN
>To give credit where credit is due, it was the class with Jeff Headley that "discovered" this idea, as well as a trip to Krenov's school, The College of the Redwoods.
White glue is a suspension of mushy polymer balls in water, with surfactants and stuff to make the polymer(the actual glue) mushy. Apparently these ingredients soften the veneer. It cures by having the water evaporate/diffuse away along with whatever makes the polymer mushy. (same as latex paint). While still mushy, the balls fuse together into a tough film that holds the wood together.
I have found it a safe bet to do what professionals do. They do "it" enough to know if it works reliably.
Following the advice of finishing experts I am going to run through a test finish on a "scrap" of crotch veneer. I glued this test piece up yesterday, as taught in the class, and it went smoothy. I don't have a vacuum bag, so I used a multitude of clamps. Indeed, a paint brush and a tub of white glue makes veneering easy.
Re: sources of sage advice
Glenn Madsen near San Francisco
>So is there a favorite brand of white glue? Does one work better than another?
The paint brush application method: Are we talking about a decent paint brush that gets cleaned, and later reused? Or a 'chip brush' that's $.79, and tossed?
I've got a pile of veneer that I'd eventually like to use, and my previous attempts at using it have been humorous, but not very successful. And I haven't bought the vacuum bag, either.
Thanks!
>I use Lepage white glue (purchased at HD), not sure if you have the same brand available south of the border.
As for application, I've found that a cheap foam roller from the dollar store (about 1 1/4" diameter by 5" wide) works quicker and leaves a more even coat of glue than a paint brush. but then I used a cheapie 2" brush for comparison...
DC
Wonder if white glue will work with oily woods?
>Thanks, Denis.
We in the southern lands also have Lepage's glue.
Why would one want to veneer over oily woods? ;-)
