Cold Weather Finishing
Bill Tindall, E.TN
>I spray all that I can which means finishing outside and letting solvent evaporate outside. So what to do when it is cold? Well it is not very cold yet but too cold to cure varnish in a short time.
These are the trunk parts, stained with Minwax Golden Oak, as recommended by WoodCentral, and then sprayed with Benjamine Moore alkyd varnish. After applying the finish I set the piece in some vehicle, in this case the Explorer, to cure. We are far enough south that the sun works and even in December it heats a car interior to toasty warmth. With the widows up, the sun made the interior more than 30 degrees above the outside temperature. The varnish was dust free in less than an hour and the finish was firm enough to move the piece in less than 6 hours.
With lacquer or conversion varnish the finish is dust free in minutes and cured in an hour or two. Later in the year I would heat the finish to room temperature and more important, have the wood toasty warm before spraying. I have done lacquer in the dead of our winter (equivalent to late July in MN).
In this case I used varnish and will rub out and wax tomorrow. This trunk will be a toy chest and get used. I thought the varnish would be durable and more easily repaired than conversion varnish or urethane. This particular varnish makes a bright finish that rubs out well. The inside is finished with shellac and rubbed out.
