wood expansion
wood expansion
wood expansion
Virgil Hensley
>I'm building a humidor out of 3/4 Spanish Cedar on four sides. Top and bottom to be 1/4" Spanish Cedar over 1/2" MDF. Can I adhere the Spanish Cedar to the top and bottom with contact cement, or should I use a small amount of yellow glue in the center of each piece to allow for the Spanish Cedar to expand?
Re: wood expansion
Re: wood expansion
Chris Friesen
>Why would you ever use MDF on a humidor? Do you really want formaldehyde outgassing around your cigars?
Re: wood expansion
Re: wood expansion
John McGaw
>Tobacco smoke already contains acetaldehyde, acetone, acrolein, butyraldehyde, crotonaldehyde, formaldehyde, methyl ethyl ketone,
propionaldehyde, catechol, cresol, hydroquinone, phenol, and resorcinol to name just a few. Adding a bit more formaldehyde probably won't do much more harm and might just add to the buzz. But the construction details do sound a bit shaky -- I'd prefer to float the spanish cedar completely free of the surrounding structure and to make it a bit thicker if possible.
Re: wood expansion
Re: wood expansion
Dick Coers
>I agree with Chris. MDF would be a great way to kill the flavor of a good cigar. Fastening any solid wood to MDF or plywood is asking for trouble. Maybe if you gave us a sketch or idea of what you are trying to accomplish with your glueup.
Re: wood expansion
Re: wood expansion
pecker
>THis is what Wikipedia says about humidors.
"The ideal humidity in a humidor is around 65-75%. The more empty space, the more readily the humidity will drop.
Humidor cases are typically made of woodboard with an interior veneer of Spanish-cedar wood or mahogany.
Spanish-cedar is the most frequently used wood for the interior veneer of humidors. It possesses the following desirable characteristics for cigar storage:
1. It holds more moisture than most woods, so it helps maintain humidity.
2. It imparts its aroma to cigars if they are stored in it for long enough. For the same reason, some cigars are wrapped in Spanish-cedar sheets before they are sold.
3. Spanish-cedar wood can repel tobacco beetles. These pinhead-sized beetles can ruin entire stocks of cigars. They eat the tobacco and lay eggs, causing further infestation. They can also be discouraged by ensuring the humidor does not get hotter than 20�C (68�F).[1] The beetle eggs usually only hatch at around 25�C (77�F), although there are also instances where they will hatch at cooler temperatures if the humidity is too high.
4. The wood properties are not prone to "warping" or "cupping" in high humidity.
Each humidor has to be seasoned after being bought or having been dry for a while. This is done by taking a moist cloth and wiping down the interior to remove any dust. A small container of water is then placed inside the humidor and left for around 12 hours with the lid closed. If the water is gone or mostly gone, then this is repeated for another 24 hours. When the liquid in the container stops evaporating, cigars can be placed in it. The humidifying element or "sponge" keeps the wood moist, which in turn keeps the cigars moist. As well, the use of distilled water is recommended for its lack of minerals, additives, or bacteria.
Sometimes, bacteria and mold can begin to build up within the humidor. Unfortunately, mold can ruin an entire case of cigars and any cigar with mold on it should be removed immediately. Some companies offer solutions that help keep the humidity of the humidor constant, as well as prevent mold."
I wouldn't want mdf anywhere near that environment
Re: wood expansion
I'd use solid wood...
>...for the top and bottom, too. I don't know how big the box is or how you will humidify it, but no matter how you build it, I would design for shrinkage/expansion and cupping. Even though cedrela is very stable and decay resistant, the differential moisture inside and outside the humidor will exert forces that will make it want to change width and possibly cup. Usually, the best approach is to make the top and bottom as panels that float in grooves in the sides. Make sure you leave some expansion room at the bottom of the grooves.
Ellis Walentine, Host
