Teak Oil on...Teak
Teak Oil on...Teak
Teak Oil on...Teak
Tony - Memphis
>I'm building a garden bench out of teak. I'd really like to maintain the nice brown teak color. This bench will reside under a covered patio and will not be exposed to much sun or rain. I've seen all sorts of products (many on marine supply sites), but thought I'd ask if anybody had any experience with anything.
I happened to be at a local wood supplier when they had teak on sale...marked down from $37/bdft (8/4 - ~6" wide). I'm almost done but I'm afradi I may run out of wood before I'm done. Hopefully not. I didn't have a plan finished and it was the last day of the sale, so I just had to wing it. Tempted to use something else as the slats since they will be covered with cushions.
Thanks,
Tony
Re: Teak Oil on...Teak
>Tony,
Sorry I don't have experience with this, but I thought it funny that Rockler advertises Behlen Teak Oil with "Unlike linseed oil and most other oil finishes, which become tacky when exposed to heat, Teak Oil penetrates the wood, dries hard and stays hard."
However, look at the MSDS for the product and what does it contain: about 50% linseed oil plus solvants (mostly naphtha), and metal compounds, I assume, as driers.
paul in AZ
>I had sailboats with teak decks and rails for many decades... mostly in salt water.
If you start with nice fresh brown teak there are any number of oils sold in marine stores that will work for a while. Exposed to salt water and direct sun these might be good for 6 months. You might get more on your deck. The "deck" oils in the borgs are a waste of money. Buy only the best .
Once it loses it's color and goes grey the quickest remedy is one of the two part solutions to bleach the wood. The first is a strong acid and the second a neutralizer. from there you start again with fresh oil.
Over many years this will eat away the softer wood leaving a slightly rough surface. Not really that much of a problem. If objectionable, I used a pull scraper to shave it flat. Then back to a finish. It can be sanded but teak is damned tough wood as you already know.
Another route is a good marine varnish with UV protection. You do have to stay on top of that to quickly recoat any scuffs or cracks. If varnish gets out of control and patches go grey it has to be scraped off and you start again. It does look good though.
A reference site: http://www.boatus.com/boattech/casey/29.htm
Once you get tired of the maintenance, letting it stay grey is a pretty common option.
Rob Stokes in North Vancouver
>I use a simple tung oil finish on the teak on my boat. The boat is stored out of sun and rain and the finish lasts well. It literally takes me an hour per year to restore it at the beginning of the season - scuff gently with 220, re-coat with a cloth, go over it again, move on.
Rob
Jim Dillon
>Tony,
Bob Flexner (wood finisher guru and author) comes down pretty hard on the speciality oils (teak, rosewood, walnut, oak, birch, ash) sold as... well, something special. According to him, they are simply repackaged mineral oil, mineral oil and wax, linseed oil and varnish blends, or some other oil/varnish mix, all with virtually no UV inhibitors. [Bob Flexner, "Understanding Wood Finishing", 2005.]
We have several pieces of teak and Asamala (a teak look-alike) deck furniture that have been out in the Maryland weather for 12 years and are put under semi-protected cover during the winter months. They have no finish, have held up very well, with just a little bit of checking on some exposed end-grain. A couple of years ago I LIGHTLY pressure washed them as I was also cleaning the deck. They cleaned up really well and I was pleased. So I vote for the letting the teak weather. If I were putting a finish on, I would listen to our WC folk who have boating experience and choose a good quality penetrating oil of some sort, and not a film finish because of the hard work necessary to prep the wood and reapply the finish. To me, that would get old very quickly - and has on a spar-varnish coated oak deck rocker. Hope this helps.
Jim
Thanks
Tony - Memphis
>I appreciate the input. Now I just need to figure out which specific product. Here is a Sketchup model of the bench. I've changed a few things as I went, but this is a good idea of what it looks like. I just realized this model doesn't have any back slats or seat slats either! Oh well. I'm sorta waiting to see how much material I have left after I get the main structure done before I decide on the sizes of all that anyway.
Tony
