Have a question? Ask Woody!
Update on Spiral Bit/Oak floor
>Several days ago I posted a question about using spiral bits to cut hardwood floor. I had trashed two $14 carbide bits in about two hours. Went to Harbor Freight and found three spiral HSS bits for about $6.75, bought 6. Turns out the real magic was the realization I could locate the nails with magnets. I had some small ceramic magnets. Just slide them along the joint and they "hop" to the nails. Marked them with chalk. Took about fifteen minutes to mark all the boards across a 13 foot floor. Then it took about an hour to cross cut them in a staggered pattern. Got through it with one bit and no damage to the bit and best of all, I was not killed or worse by flying bit parts.
Re: Update on Spiral Bit/Oak floor
Barbara Gill, Remlik VA
>Sorry I didn't venture over here when the question came up. We frequently used a spiral bit when doing special floor designs. We bought them from Eagle but that was a long time ago.
Joseph Mulherin, Sr
>Glad to hear the good news. Am also glad my suggestion helped you.
That Was a BIT of Good Fortune, Barry
Alex Grigoriev
>HSS bits are much less likely to be damaged by nails, considering that those bits are also used in the metalwork mills.
