Vacuum bag question, can I run two bags?
Brad T
>Just curious for those that understand vacuum bagging, can I run two bags on the same pump without the pressure dropping in half? Just using one line and a splitter of course.
Thanks
Brad
Re: Vacuum bag question, can I run two bags?
Dick Coers------WebKitFormBoundaryv54aV+RmMmGf6euZ
>Sure you can. It will just be like a bigger bag. You have more volume of course, so pumping down will take longer. I've never used the technique, but know that some will use a shop vac to remove most of the air and then hook up the pump to pull the vacuum.
Carol - now back in Dubuque, IA
>Yes. You may run as many bags as you wish. It may take longer for the pump to evacuate the air from the bag set-up, but as long as there are no air leaks, no problem.
Vacuum is the removal of air from an enclosure (the bag). The outside atmosphere applies the "pressure" to the airless enclosure. The pump just removes the air. It does not supply pressure. The atmosphere does that.
A pinhole (or big hole, doesn't matter, a hole is a hole in this case) in the bag allows the outside atmosphere to get into the bag. Result: lost vacuum "pressure." It is confusing because we tend to use the same terms for positive air pressure as supplied by an air compressor.
My question would be, why would you want to run more than one bag at a time?
Addy protocol: I used to teach vacuum technology for woodworkers back in the late '90's at the local community college.
Brad T
>Thanks for the responses. Carol, I want to run two bags to speed up the panel processing. One bag is gluing up panels with Unibond and is tied up for long periods, the other bag is being used for panels with Titebond and I can turn them around in an hour or so. Being able to use both makes me a bit more productive and time is money. I tend to do a large batch of vacuum bagging and then nothing for a period of time.
Brad
>Don't forget to put a valve on both bags. The pump will have to continue to service the bag you want to continue using while you do turn around on the other bag.
But then you knew that, didn't you. :-)
