thinning glue
thinning glue
thinning glue
scole
>is it possible to thin out titebond waad glue?.
Re: thinning glue
say again?
Bill Tindall, E.TN
>If you mean white or yellow, each can be thinned 5% to slow set time according to the manufacturer.
Re: thinning glue
I wouldn't really want to.
>If you thin (dilute) a glue, particularly something like a yellow glue, it's going to lose a lot of its adhesive properties.
Some examples:
I've "thinned" or added stuff to epoxy glues to color them or to get an effect (brass key shavings, malachite, turquoise). I've had reasonable luck with fillers - up to 30-40%. But I'm using them as fillers - not as an adhesive. You do need to keep the balance between the two parts. Have too many additives and it will interfere with the curing.
I've thinned out hide glue - added more water. I've used this as a "sizing". I've also thinned it so it would seep into thin cracks. I wouldn't thin it too much when I'm using it as an adhesive.
I've thinned urethane glues (2 part) to improve flow characteristics. It works fairly well. The solvents are evaporating anyway. You can even get a reasonable bond. But it doesn't work that well with wood because you have so many voids to fill.
Yellow glue uses small spheres suspended in a matrix. You really want a reasonable "concentration" of these spheres to be present when all of the liquid goes away. That's what helps the glue stick the parts together. If you thin it too much, you won't have enough spheres in the right place.
That being said - can you thin it? Probably - run an experiment or two. Thin some and brush it on a overlapping joint. Let it cure and see how much force it takes to break the joint (and where it breaks). If you feel that it compares well with the original, then you don't have a problem.
Look at what you are trying to tie together (see picture below)- there is a fair number of pores, voids and other holes. They've got to be filled for a reasonable bond to occur.
My $0.02.
Re: thinning glue
Re: thinning glue
Lee Schierer - McKean, PA
>You didn't say why you feel you need to thin the glue. To get glue worked into a small crack, a neat trick I've used is to use dental floss to work the glue into the crack. It will pull glue into an unbelievably small crack.
Lee
Re: thinning glue
that's a tip we can all use!
Bill Tindall, E.TN
>Now I might look forward to teeth cleaning where I get free rolls of the stuff. Think woodworking....as she scrapes away.
Re: thinning glue
Great Tip
>I agree Bill,
Next time I go see the Dentist I'll be thibnking of floss as well as the custumary "dental" molding. :<)
George
