OT - Welding Helmet Failure
Tom MacGregor
>I was stick welding with an auto-darkening helmet and had it fail to darken just once. Got a nasty flash in the face at close range. It's worked okay since. The only thing I can think of out of the ordinary is that the time it failed to darken there was a lot of light coming from behind me shining into the inside of the helmet before I struck the arc. Could that have made a difference? Observations appreciated as I'd like to avoid having it happen again.
Re: OT - Welding Helmet Failure
>I had one that quit working after I left it in a cabinet for several months. I was told later to leave them in the light, which I do now. The non-functional one was revived.
I only mention this in case your's happens to be on the edge of not working due to too much darkness.
Bill Howatt
>It is my understanding that even if it doesn't darken and you get a lot of bright light, the nasty UV is still blocked.
Bill
>Yikes. When I got my first autodarkening helmet many years ago, I checked into the safety. Perhaps they are different now, but then I read that welders who worked all day were advised to get the better quality helmets with a quicker response time. The less expensive "hobby" helmets were slower to respond and after working with them all day welders reported some burning of the cornea (feels scratchy). This indicated to me that the darkening itself was necessary for protection.
I always check my helmets before using them. I swing them towards then away from a bright light, such as an indoor overhead or the sun outside, watching the glass. This sudden light should trigger the darkening effect.
BTW, I once asked my eye doctor about the long-term effects of accidentally burning the eyes with welding light - was there any permanent damage? He said the strong UV will burn the surface of the cornea, somewhat like a sunburn, and the eyes will fell very dry and scratchy. (Does the same thing to skin.) This would heal itself, usually in a day, with no permanent effect.
