Rip Fence - or Swiss Army Pocket Knife?
charlie belden in san jose
In an earlier thread on the pros and cons of Long Fence vs Short Fence it was noted that the table saw �rip fence� is often used for other types of cutting and should accomodate a host of other operations - sacrificial face for rabbeting/rebating with a dado blade, tenoning jigs that use the fence as a guide, a stop for a Stop Cut, jigs for cutting slots in the corner of a box for �feather� splines, jigs for cutting angles in end grain, tapering jigs, etc.. AND it should also allow for attaching Board Buddies / feather boards and other �hold the stock down on the table� and �pull the stock into the fence�. It can also be used, in conjuction with the miter gauge, as a stop for cross cutting to a specific length or for notching a board at a specific location. Folks keep coming up with new ways to use The Fence.
Now technically, the table saw fence was intended for rip cuts - to cut a board to a specific width - and with parallel edges. And technically, a rip cut is With The Grain, as opposed to Acrossed The Grain aka a Cross Cut which are better made using the miter gauge - or better yet - a chop saw or miter saw. When it comes to sheet goods though, there is no With The Grain or Acrossed The Grain. You CAN put any edge against the fence and make a cut parallel to the fence. And because you can, folks cut sheet good panels using the fence.
So The Fence has become a woodworking equivalent of the Swiss Army Pocket Knife - used to make a host of cuts for which it was not originally intended - in part because it CAN, and in part because most amateur / hobbyist woodworkers cannot afford, or choose not to buy tools or machines specifically designed to do these �non rip� cuts / operations. A vertical panel saw will make short work of cutting up sheet goods, and do it more easily and safely than doing it on a table saw. And there are sliding tables for table saws which also make working with sheet goods quicker, easier and safer than just using the rip fence. Festool�s plunge saw and straight edge guide will do the job just as well and about as easily, and surely safer.
Dados can be done with a router and an edge guide, or a router table and fence, yet a stacked dado blade and the rip fence is often the first choice for cutting dados.
A sliding compound miter saw can cross cut up to a tad over 12� and cut compound angles quickly and easily. But often special jigs and/or miter sleds are built to do those cuts on the table saw, often utilizing The Fence..
So my question (finally!) is �Why turn a table saw into a Swiss Army Pocket Knife?�
Is the reason monetary - a tool budget that won�t permit separate tools / machines?
Is it a space constraint thing - no room for another tool or machine?
Or is the answer �Because I can.�?
Re: Rip Fence - or Swiss Army Pocket Knife?
That is a good summary of the Rip Fence
Bill Tindall, E.TN
>For those that watch Alton Brown (my hero) cooking show, he proposes that the only thing in the kitchen that should not be multitasking is the fire extinguisher. Every professional woodworker I have met gets as much out of their tools as these tools can give. I am always amazed at how few tools professionals have, be it a turner, carver or cabinet maker. So every tool can be/should be/ will become/ a Swiss army knife.
As my skills developed I followed the same path, so I think there must be something innate about this development. It would naturally follow then that the table saw would get used for all that it could do, unless the shop owner had unlimited space, money and time to invest learning a new tool.
I recently took a reproduction furniture class in a professional shop (Mack Headley and Sons). Their radial arm saw sat buried under stored lumber. The table saw was festooned with all the additions and jigs described by Charlie. A big sled obsoleted the radial arm saw. On the other hand , a kitchen cabinet shop would likely have entirely different tools geared to sheet goods- panel saws and/or CNC.
