OT - Electric Motor ?
Ron In Sterling CT
>I have an old Atlas Drill Press that has served me well over the years. Recently the motor started acting up. When I turn the switch on the motor just humms. The drill press rotates freely, and as soon as I give the quill a twist, the motor starts up and runs okay. I can turn it off, then turn it back on while the drill is still rotating and it starts up just fine. I thought maybe the motor was dirty, so I blew it out with compressed air. Certainly made a shop full of dust, but didn't help any. The information on the motor plate indicates that it is a Dayton 1/2 hp, 1725 rpm, capacitor motor. Can you motor guru's tell me what might be wrong with it, and can I fix it, or do I need to take it to a motor repair shop?
Ron
Re: OT - Electric Motor ?
al h
>I would have the motor start capacitor checked first...that symptoms you are describing sounds like the capacitor needs to be replaced. it could also be the starter winding on the motor (if it has one) maybe even the switch itself...but i strongly suspect the capacitor.
I agree,
>Take the capacitor to a motor shop or any supply store that can replace it. You could just replace it and see if that does the job or the shop might be able to test the old one for you. (The capacitor is in that bulge on the side of the motor about the size of a small juice can.) Be careful removing the capacitor even with the unit unplugged, it could still be holding a charge, even if it is partially defective, so don't short the leads.
You may be able to pull off the "back" end of the motor and check the centrifugal switch. If the contacts are stuck or the unit is full of sawdust, you may be able to fix it. Polish the contacts with very fine sandpaper.
If this is beyond what you want to do, take the motor to a motor shop.
Concur
Richard Jones
Thanks to All for the Input
Ron In Sterling CT
