Bar design - Help!
Bar design - Help!
Bar design - Help!
Scott in Douglassville, PA
>Hi, all -
I've been asked to build a bar for the sis-in-law's new basement, and I'm running into some trouble. The basement (a) has nice hardwood floors I don't want to permanently attach anything to, and (b) may be transitional - don't know if the sis-in-law will be in the house permanently. With that in mind, I have a few design constraints I'm trying to work within:
- The bar's gonna be big - 10' or so.
- The bar needs to be freestanding. Can't affix to the floor.
- Ideally, the bar's gonna need to be modular, somehow, to get it from my house to hers.
- The bar needs to be, ultimately, movable, uncase SiL relocates. Goes back to modularity.
I'm thinking of stealing, um, borrowing some ideas from a Shaker workbench and adapting them to something more grandiose. I'm considering frame and panel construction, tapered or turned legs at the corners, all kinds of disparate stuff. Don't know if any of it is good design or not.
Help!
Anyone have any good ideas, resources, suggestions, pictures to share?
(The whole bar project is really only an excuse to get her to let me build some Windsor bar stools, naturally...)
Thanks for any help.
Scott, long time, no post
Re: Bar design - Help!
Help!
Wow, Scott, you came back with a bang. The trouble with bars is that they tend to rely on being anchored to the floor, because they usually consist of a front wall and a top, usually with a return that stabilizes the whole shebang. There's no way to get around that unless you provide what amounts to a supplemental "floor" (thinking out of the box here). In other words, anchor the bar to a piece of plywood that sits on the existing floor.
I don't know that you can depend on a freestanding design to stay put.
Ellis Walentine, Host
>OK - some weird thoughts running around in my head.
Did you want a cabinet style bar? I.E. have a serving side of the bar on one side and have a cabinet on the other. In which case, there wouldn't necessarily be any turning or legs. How about you build three cabinets with toe kicks on the front and the back. Make two of them ~3' and one of them 4'.
If you are really eager to do some turning, do some "split spindle" turning by gluing a blank together w/ paper or newspaper in the center. Turn your spindles (2 of them) and then split at the paper/glue line. Use these on the "front" near the corners of the bar and also at the lines where the base cabinets are joined. You can do something similar on the service side (as opposed to the serving side).
Join the three base cabinets together with a single 10' long top. You can use frame and panel construction if you want, but I'd only do that with the front side.
Just a thought.
Re: Bar design
GalenV
>For ideas there seems to be a lot of web sites with pictures for bars.
http:www.barplan.com/products.htm can provide plans and even design modular units. Another is http://www.pokertablesetc.com/barstools-bar.asp. A lot of them seem to have enough mass and wrap around that would be very stable stand alone.
If this is to be a straight 10 feet the cabinetry could have a false bottom and put weight for stability. On wood floor you could set on the non-skid pads for area rugs, just probably be glued to the floor from the compreesion over time!
Stock it up with enough liquid refreshment and it will add weight!
If you do not put a lot into it just let her sell it with the house.
Would always give you another chance to build another.
Thanks, Ellis. I try. ;)
I have a neighbor with a 'freestanding' bar. Essentially what you said, with some plain feet on the corners. It's only about 3" off the floor, and the bar's only about 5' or so, so I don't know if it'd translate to a larger setup.
I need to break out some paper and try to draw something. Having a hard time visualizing what I want to do...
Thanks for the input.
Scott
>Interesting idedas, JL. Thanks. I like the idea of the split turning...
Re: Bar design
Good point... ;^)
A simpler idea?
>How about building the bar with at least one corner for stability and putting rubber feet under it? If you absolutely had to, you could add one or two toe-screws into the floor to keep things stationary.
Just looking for an easier solution...
Tom Goltl
>I just built this bar. Free standing straight bar. The plans call for a 12' bar but it tells you what components to change to make a smaller bar. I built my base at 7' and the top will endup being 8'. The plans were decent.
http://www.precision-images.com/id133.htm
Good luck
Tom
>Tom, that looks like a perfect starting point. You don't have pictures of your completed (or partially completed) project, do you?
Thanks!
Scott
Tom Goltl
>I can take a few. I esentially have two matched bases that are 42" long. They screw together to make a 7' piece. Very heavy and very sturdy. I'll try to take a couple pictures and send them. I had to do some figuring with the cut list they provided, but everything turned out great.
Tom
Tom Goltl
>Here is a picture of the front. Eventually I'll screw it's twin to this and attach a top.
Tom
Tom Goltl
>Here's the back. Pretty much put together with pocket hole screws.
Tom
