ADVERTISE HERE - FREE TRIAL
Transfer to Wood....
john l. blue
>I've put together an outdoor coffee table, sorta wonderin' how
to transfer newspaper articles onto the table. Blue
Re: Transfer to Wood....
Decoupage?
>Is that what you are looking for? We used to glue paper (including newspaper) to wood and then bury it under multiple layers of polyurethane.
Don in Vancouver,WA,USA
>If you have an inkjet printer you can use Inkjet Water-Slide Decal Paper. You scan the article or photo into the computer. Then use something like IrfanView to get the image to the desired size. Print the image onto the special paper. Spray the paper with a couple of coats of clear varnish and let dry. Soak the paper in water and the "decal" slides off of the paper. Glue to the coffee table. If the coffee table is really dark you could lighten it with a coat of Gesso of white latex. The pic show a toy box I did several years ago.
Re: Decoupage?
john l. blue
>What I'm trying to do is to transfer the ink from the newspaper
to the wood. I've tried soaking in water putting the paper down,
but it doesn't work. I've actually done it, should've written
down how. Thanks.
john l. blue
>Appreciate it. What I'm trying is a little different, as I'd
like to just transfer the ink from newsapaper articles to the
table even if it reads backwards.
GalenV
>Not sure if you have specific newspaper print you are trying to reproduce or not.
You might find someone who does silkscreen printing and maybe find old silkscreens they may let you have?
Not sure if you could use metal offset printing plates and transfer as it would take a lot of setup.
What about the iron on transfers they use for tee shirts and the like. You can buy the computer paper and put you own image on it.
Just WAG
Galen
Re: Transfer to Wood....Heat transfer
Kneale Brownson dreaming of snow in N. MI
>The process is called heat transfer. You can use an inkjet printer to put the reversed image on the paper, then transfer the image to the wood with heat. I have a heat press we use to transfer inkjet images to fabrics (Tee shirts and quilt squares, for example) and I've used it to put stuff on wood too.
john l. blue
>appreciate the info!
john l. blue
>The info, I appreciate it!
