THE WOODRAT IS BACK!
Lumber moisture content.
Craig Todaro
>I have a load of basswood i've been air drying for 80 days. I'm gonna check the moisture content of the lumber with a hand held tester. I was wondering how low do i have to go to be able to glue this lumber without worrying about it not adhering correctly?
Thanks for any and all help.
Craig
Re: Lumber moisture content.
Couple different issues here
>Drying wood isn't all about gluing, it's mostly about dimensional stability and to an extent about finishing. While moist wood won't glue well with certain types of glue (e.g. PVA), it will do fine with moisture-catalyzed glues like polyurethane glue. The reason people dry wood is so that after they have turned it into furniture or architecture or whatever, they don't have to watch the fruit of their labor bow, cup and twist itself into oblivion, or shrink so much that the design fails, e.g., panels shrink out of grooves, joints come apart, etc.
Basswood shrinkage characteristics are not very good. It shrinks a lot, and the difference between radial and tangential shrinkage is pretty significant, too, so it will tend to cup as it dries. That means that if you mill it flat now, it will likely cup by the time it's finished drying. It's all relative to the width and the grain orientation of the wood.
I think you would be better off if you let it dry to the 8% - 10% range before using it. If you don't have a moisture meter, you can determine MC with an accurate scale and a microwave oven, which I won't get into here. Keep in mind that air-dry time depends on thickness, which you haven't mentioned here. Thick stock takes much longer to dry, figure a year per inch on average.
Don't know if this is helpful, but your question is kinda open-ended.
Ellis Walentine, Host
Different Question's Answer
>Craig,
You need to wait for the wood to reach EMC "Equalibrium Moisture Content" before you work it. Until it reaches EMC, the wood will continue the shrink and change its shape. If you try to confine it with glue joints before it reaches EMC, you'll more likely get cracks, checks, and/or broken glue joints.
EMC is different for many areas. In Arizona it may be 5% whereas here in Jersey its at least twice that. The old standard was "1 year for each inch of thickness" before air-dried wood can be worked with confidence. That lets the boards go through a "natural" series of seasonal shrinks and expansions to reach the stabilized dimension.
mm
data from Franklin
Bill Tindall, E.TN
>I asked this question of tech service at Franklin adhesives company. I was told that 12% was ok but at 12% the set time is greatly increased. I don't remember the number for sure but it may have been 24-48 hours at 12% MC in the lumber. You don't say where you live but this lumber would benefit greatly from some heat, like in a loft or attic or some other arrangement to enhance the drying rate. Or maybe you live in AZ and just outdoors will be hot enough. But if you live in Michigan I doubt the lumber is sufficiently dry after 80 days for furniture work.
Craig Todaro
>Thanks for the responses. I guess i should of been a little more clearer. This is 3/4" bass wood. Mostly 5" wide to 16 inches wide. The wood has been stickered with air dry stickers for 80 days. Under roof but out side. I live in Pennsylvania. I'm just using this lumber to produce Basswood fur stretchers. I used to buy kiln dried lumber but it was getting to expensive for this hobby. I decided to start buying green and air drying myself. After i work with this load of 3000 board feet i'm sure i will learn a few things. I checked the moisture with a hand held tester lastnight and it was reading 13%. I'm not to concerened about a little shrinkage after the board is shaped. I use weather proof glue with the extended working time. I was just worried about gluing boards together and the joints not holding if the moisture level of the lumber was to high.
Sorry for rambling. I just wanted to try to make everything as clear as possible.
Fred Davis
>Gee Craig ,
how much Fur are you stretching, 3000 B.F. , bear hides ??
In any case it sounds like your about as dry MC wise for ouside conditions as you will get.
Craig Todaro
>I'd hate to try and stretch a bear hide. I make and sell the fur stretchers. Wholesale and retail. I was never able to find a supplier that could keep me supplied with dry lumber. Thats why i buy it green now and wanna air dry myself.
