OT: SD card download
Bill Roland (Mt Juliet, TN)
>Last night I tried to download some pictures from my camera SD card and it would completely lock-up the computer. The computer is a Toshiba laptop running XP with the latest upgrade. I tried using the wizard to download and direct copy mode but it will not complete the preview before lock-up.
Any ideas?
Re: OT: SD card download
How's it attached?
>Internal SD card reader, or external SD card reader with USB connection?
Do you get a the little Window's "da-ding" when you plug it in or attach it, before it locks up?
When was the last time it worked on this computer?
Can you try it in Safe Mode?
Do you have an alternate (computer, SD card, reader) you can try in order to isolate the problem?
Happy Woodworking?
Re: How's it attached?
>It is plugged directly into SD slot on computer. I also tried another SD card and it did not work either. I'm going to try it tonight hooked through my printer. I have used both methods in the past and they both worked.
Re: How's it attached? more
>Yes I do get the "da-ding" when I plug the card in and the window comes up that asks what to do, I click the one for loading the pictures to the computer and the next window comes up, then it locks-up.
Okay then
>If that's the case then, it might be the program associated with that media type.
You know how when you plug in a certain USB memory drive it will ask you what you want to do (open the folder, play in Media Player, copy to disk, open program XYZ, do nothing, etc) and to remember the action for this media type. It's possible that it's set to do a specific task or program that is locking up the computer. I can't remember how to reset that at the moment.
Happy Woodworking!
Re: Okay then
Hamish------WebKitFormBoundary5fRmuq+AgGjgpUJW
>You could just plug your camera into the computer with a USB cable instead without withdrawing the SD card. Hamish
