ADVERTISE HERE - FREE TRIAL
Lewis & Clark hardware
>Here is the photo of the Lewis & Clark hardware that Russell sent me. Any idea what these things are?
Re: Lewis & Clark hardware
Ron Bauman
>I believe #99 was used during glues ups. When joining two boards on edge they were placed together and glued and the "dogs" were driven in one "tooth" on either side of the joint the tapered "tooth" drew the boards together until the glue set.
Hank Knight
>#94 appears to be a wrench of some kind or perhaps a crank or handle for a square shaft. #95 is clearly a "C" clamp. #96, 97 and 98 are bench dogs identical to the one in the photo Rob posted. They are a little different configuration from the ones I've seen and described in my original post below, but they work the same way. #99 is a set of pinch dogs. For non-woodworkers, pinch dogs are used to hold the edges of two boards together for gluing. The boards are butted together long-edgewise. The pinch dogs are driven into the end grain bridging the joint. The wedge shape forces the edges together. When the glue sets, the dogs are removed. Pinch dogs are available from woodworking supply houses today and are exactly like the ones pictured as part of Lewis and Clark's kit. Here's aphoto from the Lee Valley online catalog:
Pinch Dogs
Dick Coers
>#94 looks like a bed bolt wrench
Maybe #96 is upside down. Looks like it could be driven into a wall or door jamb, then be used for hanging lanterns, provisions, etc. Some of their camps had to be for a short setup, but other camps would be for the winter. There had to be many custom devices for lashing, temporary fastening, and used where you cut your logs and build your structures at many different camps.
Re: Lewis & Clark hardware?
>I think those are reproductions, the nail header may be old. Judging from the original post, this is what they think they looked like.
Stephen
Hank Knight
>Stephen, what's a "nail header"?
>Hank,
It is no 94 at the bottom and was used by the blacksmith to make nail or spike heads. The square tapered spike was put in the header, cut off and then pounded into the head shape, some heat may be involved.
Those tripartite bench dogs would bother most modern woodworkers as they need to be pounded into the workbench to hold the work.
Stephen
Hank Knight
>Thanks, Stephen. That makes a lot more sense than my guess.
>Workbench - I am thinking it would be a log upon which they used an adz to level out a spot :). I don't think you could get a bench on a canoe or small boat.
Frank Orfanello
>You're right. Their glue clamps.
