A55 Smoothing Plane
OT Help w/ tricky install of garage door opener
Ralph Turney
>Hey all,
I have moved into a new condo that has an existing roll up garage door, I bought an opener, BUT there is a beam that comes down 15" from the ceiling that runs across the garage and it's 8'9" back from the front wall. The top of the garage door when open is about 11" from the ceiling. Now, everyone I talk to says you need at least 10' for the opener to fit, or cut it down to fit. The problem with that is that the garage door will not open all the way and I'd have to duck every time I walk in...unacceptable. I don't want to drill a hole in the beam as it's a condo and I'd hate to have to fix it if the nanny neighbor sees it.
My question is, has anyone lowered the back of the door down (instead of the open door being lever, it would now slant downward to the back) to give room for the opener to be mounted under the beam???
I hope this makes sense, I'm getting tired of jumping out of the truck to open and close the door all the time especially since I already bought the opener. Also, my daughter will need to get in and out of the garage and it's very hard for her to open it manually.
TIA
Ralph
Re: OT Help w/ tricky install of garage door opener
Take a look at Wayne-Dalton Door Mounted opener
Marvin Horn
Yes, the WD Torque Master is great *LINK*
>I struggled with garage door openers for years at this house. I have a similar beam that causes havoc with proper placement of garage door openers. I tried a chain drive, belt drive, screw drive.... all had the same problem.
I finally discovered the Wayne Dalton Torque Master and it's fantastic. I really don't understand why we don't see more of them around. They solve so many of the traditional openers problems, including placement, noise, speed, etc. Perhaps it's a patent issue or something, but the Wayne-Dalton is such a different way of doing it that it makes the traditional types seem pretty silly.
The only trouble with them is availability and support. They used to sell them locally here at Lowes, but they stopped carrying them, so now the only way to buy one is online. Their customer service is great and they shipped me replacement parts long after warranty expired. However if something goes wrong with it, there's nobody that can come and take a look at it. Right now, mine is about 7-8 years old and it's not working. I might be faced with having to buy another one to get it working. But even if I have to, it's worth it in my opinion.
There are two models, one made for a Wayne-Dalton door, and one for other brand doors. I have a CloPay door and the one I have works well. Another bonus it it's easier to install.
Happy Woodworking!
http://www.waynedaltonstore.com/product/7417141095
Sorry, Wayne-Dalton iDrive *LINK*
>Sorry, I think I had the names wrong.
Wayne-Dalton is the manufacturer and "iDrive" is their overhead door opener.
TorqueMaster and/or Torsion are the models depdneing on the type of door you have.
I may still have this wrong so check here: http://www.waynedaltonstore.com/wayne-dalton-idrive.html
Happy Woodworking!
Chuck in ND
>If the door is hard to open as in being heavy, then I would say the springs aren't adjusted correctly and will probably shorten the life of your new opener. You should probably have a door company inspect it and then have them install the opener. Garage door springs aren't something that just anyone should be messin with.
Lee Schierer - McKean, PA
>I have a garage that doesn't have enough room over the door when it is open for the garage door opener rail to fit. A friend in the garage door business suggested mounting the opener back behind the door when the door is fully open and connect the traveler to the top of the door with a piece of ridgid conduit. The adjustable S bracket that cam with the door fits nicely inside slightly flattend 3/4" conduit. The door fully opens and fully closes. The door has operated perfectly for more than 20 years.
Lee
Yup, Wayne Dalton
Alan in Little Washington (NC)
>Wayne Dalton I-drive is the way to go! I put three on my new house four years ago. They are faster, quieter and generally quicker and easier to install than other door openers. Excellent, full color manual- MUCH shorter, but rivals the Leigh jig manual!. All the controls- keypad, buttons, remotely controlled lights (one is visible in upper right corner of pic- can be plugged in anywhere), are wireless and programmable. The unique design received an award.
Now the other side of the story. These units did have some problems and some folks got quite annoyed. I had one unit stop working. L-D customer service patiently talked me through testing it - over a half hour on the phone (their dime). It was a bad controller circuit board which appears to have been the problem with a number of these units. They sent me a completely new board which was easily installed (plug and play). I have had no problems in the four years since. The early problems may hvae given L-D Idrives a bit of a black eye, and not sure if this is the reason, but Lowes stopped carrying them a few years ago. They were also in the upper price range of door openers (though well worth it IMHO). It appears they have reworked and/or upgraded the design (according to their web site). I actually had two problems, but one was a bonehead error on my part- I incorrectly connected the obstruction electric eye. While I said they were quick and easy to install, you still must follow their, clear, step-by-step instructions. You also may need to tweak the original door installation. The W-D Idrive is not as forgiving of bad door installations as other openers. Two of my three Idrives are just visible in this pic, partially hidden by the door tracks. The PVC pipe is my DC ductwork.
Wayne-Dalton news - amazing
>As fate would have it, we were looking at buying either a whole new opener ($309 online) or possibly a new circuit board ($159) to repair our old (2000 or 2001 i think) opener. I had tried on several occasions to reset it or fix it to no avail. Well, prompted by this thread, my wife called them this morning, explained the situationand they spend quite some time with her. She worked with them with a phone in one hand and a screw driver in another taking things apart. By the end of the call they had it working again.
We're talking about a garage door that is 7 years old (I think).
Not only is the product's design fantasic, but the company is equally amazing. I'm a customer for life.
Happy Woodworking!
Re: Yup, Wayne Dalton
Ralph Turney
>Thanks everyone, I'm convinced, that opener looks like the WAY to go!!! Now, I sure hope I can find the receipt for the one I bought at Home Depot.
The install looks extremely clean and simple, but I have one question, how do you get that thing on the rod???
I've taken care of just about all the issues in my "new" place and that opener was the last thorn I had...I knew that if I came here I'd get the answer I was looking for.
Thanks all!!!
PS Alan...can I have your garage, please???
Ralph
Wayne Dalton...just bought one, it's on back order
Ralph Turney
>Looks like it'll work with my door, so I went online and bought one. To bad it's back ordered for a few days.
Thanks again!
Ralph
Agree 1000% with Mark
Larry in SE MN
>I had the same experience with WD Customer Service. First thing, the representative gave me her full name and phone number. I started explaining how the door had closed on a sawhorse (my dumb) and went into "garage door fibrillation" when she interrupted and began asking questions. Within 2 minutes she had sent email instructions to do the fix with a screwdriver and 10 minutes of my time. It was basically a reset of the sensor system and it worked perfectly.
Wayne Dalton customer service rocks....
One caution on the Wayne Dalton iDrive
Tim Greif - West of Chicago
>How long can you be without a door opener? For some odd reason, these things always seem to fail when the weather is cold. With a standard door opener, any door opener mechanic can have you back in business in nothing flat. Or just do it yourself if it's not the torsion springs.
Can you say that about the WD iDrive? You ordered new and it's on back order. How about if it goes bad? How long is it going to take for someone to get it back to you? If it's just a door to the shop, probably not a real big deal. But if you and the awife park in there every day and need to get to work, what then? Not trying to be uber-negative here, but it's something to think about. I'm more comfortable with things that are readily repairable when I need the use of them every day.
Re: One caution on the Wayne Dalton iDrive
Ralph Turney
>Hey Tim,
All good points, but it will be a cold day in Southern California when I call a repairman for anything yet alone a garage door opener mechanic. And besides that, a regular door opener WILL NOT fit without extensive modifications of my existing door, (I just returned the Gene to HD) so it's a moot point anyway...it's either do without one completely or settle with a relativity high tech opener. Any piece of equipment can fail and I'm sure this product is no different, but just looking at it, there sure seems to be a whole lot less parts to fail.
It's just me and my daughter, so only an X wife to worry about and if the garage door won't open, I'll just climb on my bike to get to where I want to go.
Thanks for being the devils advocate, but I think that the good (Wayne Dalton iDrive) out weights the bad (Gene) on this one. I've been without one for 7 years, I could handle it again.
Thanks
Ralph
"How long can you be without a door opener? For some odd reason, these things always seem to fail when the weather is cold. With a standard door opener, any door opener mechanic can have you back in business in nothing flat. Or just do it yourself if it's not the torsion springs.
Can you say that about the WD iDrive? You ordered new and it's on back order. How about if it goes bad? How long is it going to take for someone to get it back to you? If it's just a door to the shop, probably not a real big deal. But if you and the awife park in there every day and need to get to work, what then? Not trying to be uber-negative here, but it's something to think about. I'm more comfortable with things that are readily repairable when I need the use of them every day."
>It might be more of a concern if W-D were a new start-up or a small company. They have been around for quite awhile, and are a big company.
Re: Yup, Wayne Dalton *LINK*
>The case is only on the front half and gears are split so you just wrap each half around the torsion rod and bolt them together. The entire manual used to be on the W-D website, but I can't find it. They have an excellent video however- something you can watch one or more times, and study before your unit arrives. See the link below:
I-Drive
Ralph Turney
>It was in big red letters where you couldn't miss them right on the page that you ordered them from. So I knew in advance that it would take a little longer.
Ralph Turney
>Thanks Alan, after I asked my stupid question (remember, there are not stupid question, just stupid people) I went to their site and downloaded the manual...can't wait to see the video though.
Thanks!!!
Ralph
>After looking again I also found the manuals- not as nice as the one they used to have- mine has more colorful pics :)
Let me add/repeat a few cautions:
I found that the knuckleheads who installed my doors, didn't do a good job installing the torsion tubes- they were bowed quite a bit, which added friction that affected door operation. Before installing the Idrives, I adjusted the position (up-down, in-out) of the bearing blocks near center of the torsion tubes by the springs, to get them as straight, end-to-end, as I could. I put a light at one end and sighted down the tubes from the other end to verify alignment- concentric circles.
Be careful adjusting the spring tension. You'll need two levers made from lengths of rod that won't bend easily and that won't sit too loose in the recess, to tighten the torsions springs. I think I used 1/2" X 12" bolts I had laying around. Be careful and take it slow, rotate a little bit at a time. If your temporary lever slips out of the socket or out of your hands while tightening the spring, you'll end up in a world of hurt. Plus it will take a long time to retension the spring.
I put slightly more additional tension on the springs than they suggested which made the doors open a little easier and also slightly reduced the loud "thunk" sound the doors made as they closed against the garage floor.
While you must snug the locking bolts on the spring adjusting clamp and the idrive sprockets so these parts won't slip and rotate on the tube, don't over-tighten and collapse the torsion tube.
Don't forget to post the results of your installation after your unit arrives and is installed.
That was my point
>That was my point when I mentioned the one possible disadvantage with the WD iTorque. Because there are no stores that carry them around here anymore, and because there doesn't seem to be alot of local repair guys who know about them, it can be a little dicey if you have trouble.
But I liked it so much, I was almost ready to buy a new unit when they solved the problem over the phone with my wife. That's better service than I probably would have received with any other door opener.
We spent a few weeks with the opener set to manual-overide mode (pull red handle to disengage), and opened and closed the door by hand. I should have thought of callign themm earlier since they had us back operational within 15 minutes of calling them.
Happy Woodworking!
Ralph Turney
>Thanks for the advice Alan, I will post how the install goes. Unfortunately the original back order date of 9/26 was extended today to 10/8...I would have still ordered it anyway though. It really is my only choice.
Thanks again.
Ralph
Re: That was my point
Ralph Turney
>I agree, and like I said, I wouldn't now call a repairman anyway. The fact is, when I moved in here, there was SO much to do that I did have the manufacture of the garage door come out to fix the sag in it (the neighbors must have been running into it for years, all kinked up in the center) and the crooks (Marathon Garage Doors) charged me 280 dollars to spend 20 minutes to install two braces on it. Needless to say I won't be calling them back.
One concern that I do have is that the main garage door is the only access, no back door. Do they include or can you buy a mechanical override that works from outside the door, in case the power goes out?
Re: That was my point *LINK*
Kurt
>Here is one to do what you want
Key Release Lock P250
A hiccupe in the process...
Ralph Turney
>It looks like I'll have to engineer something myself with that keyed entry, because WD doesn't make a standard one themselves.
I just talked to three different people, the rep I bought it from, who referred me to the manufacturer, and they referred me to their local dealer about access from the outside in case of a power outage. Everyone was extremely helpful until I called the dealer in the next city over, who must have told me "good luck" ten times, while laughing at me and that his "dad" as a mechanical engineer would NEVER attempt the to install a Wayne Dalton garage door opener. If his dad, as a ME can't install a simple garage door opener, I sure hope I don't ride in or own anything his dad worked on. What a complete moron, after listening to him tell me that I didn't stand a chance in hell of installing that opener myself, I finally hung up on him. The arrogance of someone who installs garage doors for a living to assume that I'm all thumbs and a moron to boot, really makes my blood boil!!! And to top it of, he was probably just the salesman and really couldn't do it himself.
Sorry for the rant.
Ralph
I LOVE the I-drive!
Stuart Hough
>Put one on my door and got back a lot of uninterrupted airspace!
