using same brush for shellac and lacquer
RobRing
>I'm going to try brushing nitrocellulose lacquer on my current project. I have a good-quality badger hair brush that I typically use for shellac. Is there any reason not to use this same brush for the lacquer? I�m a little worried about cross-contamination � should I be?
Re: using same brush for shellac and lacquer
>No need for a hair brush; a Purdy or Wooster soft poly will work fine. Reduce the lacquer 20% and lay it down quickly without rebrushing. Best if you rotate the piece to keep the working surface horizontal; hard to avoid runs and curtains otherwise. Good luck.
Clint
yes, be worried
Fred
>the solvents are different -- any residual not washed out will be released into the work.
i learned this the hard way
now, i keep dedicated brushes for lacquer, and ones for shellac.
