Bench Dogs
Bench Dogs
Bench Dogs
Russell Greenberg
>I work at Lewis and Clark National Historical Park in Oregon and we recently had a showing of old hand tools (some thought to be like the items the expedition used). There were two items called bench dogs that I will try to describe as follows: Forged out of square material,about6-7" long formed like a "Y" the top with the two ends have sharp points, on the bottom (single end)is a flattened point more like a screwdriver(this is formed in the opposite direction as the two points at the top.
I hope that is enough of a description. Thanks for any help
Russell Greenberg
Park Ranger
Re: Bench Dogs
Not sure of the question.
>Are you asking if there is something called a bench dog? Yes, there is.
Are you asking if your items might be bench dogs? A picture would really help.
There are a lot of different types of dogs (the pun is NOT intended). You could also have a blacksmith's dog.
Re: Bench Dogs
Re: Bench Dogs
>Are these tools actually from the Corp? Or are they what they thought they looked like? Is there a description in any of the journals i.e. Patrick Gass?
A mention of a bench dog in a journal from that period may refer to a holdfast. I am sure L&C didn't carry a workbench across the continent but a hold fast could be used anywhere there is a hole.
What you described sounds like it might be a spanner bit for a brace. Do you have any photographs?
Stephen
Re: Bench Dogs
Re: Bench Dogs
Hank Knight
>Russell,
I have seen bench dogs like you have described. They were used with a makeshift bench made from a split log or heavy timber, the top of which was leveled with axes and hand planes. The single tyne was driven vertically into the surface of the "bench." The two forked tynes could then act as a stop for a timber being planed on the bench top. The two tynes actually bite into the end of the timber, securing it to the bench top. I hope that makes sense.
I'm sure Lewis and Clark didn't carry a workbench along on their trek (although, from what I've read, they carried a lot of stuff). These forged bench dogs allowed them to make a functional workbench from what was available in the wilderness.
Hank
Re: Bench Dogs
Re: Bench Dogs
Mr.Westover
>I am not sure what the tools are that you are describing, but as far as Lewis and Clarks corps of Western Discovery, the most complete inventory list we have avialible to us is listed in "Letters and Related Documents of the Lewis and Clark Expediton from 1783 to 1850" by Donald Jackson. I rememebr there being quite a list of woodworking tools and hand tools in general, but I dont rememebr there being any bench dogs or hold fasts listed. This may not mean anything, though for it is also known that there were items taken along that were not listed in the requisitions drawn up by Lewi, that are found in the book.
Even though they were travelling through wilderness, they did stop for extended periods of time along the way, most notably at Fort Wood, Illinois, were they spent the winter of 1803-1804 gathering supplies and recruiting men, at The Mandan/Hidasta villages where they built Fort Mandan and spent the winter of 1804-1805 (In present day North Dakota), and at Fort Clatsop,(Now Astoria) Oregon where they spent their third and final winter (1805 to 1806). At each of these locals it is known, for example that the blacksmith and his helpers (Johns Shields, Alexander Willard, and William Bratton) set up the forge and went to work producing ironware to trade to the local natives for food. It would stand to reason, therefore, that the primary woodworker of the Corps, Patrick Gass, would also have opprotunity to "set up shop" to fabricate furniture and make needed reapirs to wooden items for the Forts.
So, even though I dont recall seeing Bench Dogs or holdfasts (Which are also used by blacksmiths, by the way, to clamp pieces being worked on to the top surface of an anvil)on the equipage lists, it is entirely possible
Re: Bench Dogs
Re: Bench Dogs *LINK*
Rob Lee
>Hi -
Probably one of these.... sorta like "stapling" a piece of wood to a surface... drive one end into the board, drive the other two into a work surface. Just like a log dog, but for attaching/holding ON a plane, instead of IN a plane...
My understanding is that these were carpentry/construction devices, and not shop tools...
Oh Adam....where are you???
Cheers -
Rob
Dogs
Re: Bench Dogs
Re: Bench Dogs
Mr.Westover
>Ive never seen anything like this before, but I am not a woodworker, just a blacksmtih with an unhealthy obsession for Lewis and Clark. To answer Mr. Shepherd question via PM, if forged from a file, 60.00, if mild steel, 40.00
